Go to Post And while I am not that big on hero-worship, I am pretty darn proud to know Dave. However, this does not mean that I will stop picking on him - MissInformation [more]
Unread 14-01-2010, 16:52
1951-44U's Avatar
1951-44U 1951-44U is offline
ROAR.
AKA: Phil Chang
FRC #0025 (Raider Robotix)
1951-44U has a spectacular aura about1951-44U has a spectacular aura about1951-44U has a spectacular aura about
Grabbing Output from Robot Sensors
We're trying to connect the Classmate, Dev Laptop, and Robot so we can get feedback from our sensors in WindRiver C++.
We've connected it with a setup like this: dev laptop and classmate to router, which wirelessly connects to the robot. We've also tried hooking everything up directly to an ethernet switch. Still don't work.
When we try to connect with the console, the Classmate intermittently displays "Watchdog Not Fed". The robot reaction works, but is delayed when we try the drives. The output on the console has all 0 values. Without the Dev Laptop in this network, the robot works fine.
We fed, disabled, and even tried to kill Watchdog. We've tried different laptops. It still does not work.
-1951-44U
Unread 14-01-2010, 17:16
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Grabbing Output from Robot Sensors
The Watchdog not fed message means that the running program enabled the watchdog timer and is not calling the Feed() method before the expiration time runs out. If you have autonomous code that does a long Wait() you are probably running out the watchdog timer. If you have a program loop in your teleop code then you might be missing a call to Feed().
The configuration of the programming laptop and driver station shouldn't matter if they are all successfully talking to the robot.
Are you running some sample code or your own program?
Brad Miller
Robotics Resource Center
Unread 14-01-2010, 22:17
1951-44U's Avatar
ROAR.
AKA: Phil Chang
We are using our own code. There are no loops in our teleop, and we haven't used the autonomous yet. We had GetWatchdog().Feed() 's all over the teleop when we were trying to feed the watchdog.
Unread 15-01-2010, 03:06
ranc ranc is offline
FRC #2489
ranc is an unknown quantity at this point
Wait you have no while(true) or while(IsOperatorControl()) loops?
I remember leaving out said while loop and getting the same issue.
Unread 15-01-2010, 09:41
1951-44U's Avatar
ROAR.
AKA: Phil Chang
Well, we have those loops, but we have no others. We have Feed()'s within those loops, too.
Does the line "GetWatchdog().SetExpiration(0.1);" in the initializers do anything? Can I delete this?
Unread 15-01-2010, 10:59
AKA: Brad
That sets the expiration time of the watchdog timer. That means that it must be fed within 0.1 second (100 milliseconds) before it times out and the motors stop with the "Watchdog not fed" error message.
If there are any Wait() calls in your loop that are greater than 100ms, the the watchtog will also time out.
Brad Miller
Unread 15-01-2010, 15:41
1951-44U's Avatar
ROAR.
AKA: Phil Chang
Can I SetExpiration at some ridiculously high number to get rid of the watchdog error?
Unread 15-01-2010, 16:22
FRC #2489
You could use GetWatchdog().SetEnabled(0) for turning it off right before your long wait and then use GetWatchdog().SetEnabled(1) for turning it back on again when you're not initializing whatever you're initializing (i'm assuming your long wait is due to setup of some component)
Unread 15-01-2010, 20:12
1951-44U's Avatar
ROAR.
AKA: Phil Chang
I'll try that tomorrow. But I haven't a single Wait() in the program. ._.
Can I completely delete the GetWatchdog().SetExpiration() or completely replace it with the .SetEnabled()?
Unread 15-01-2010, 23:46
FRC #2489
Yes I think you could just use set enabled to turn it off
Unread 16-01-2010, 12:25
1951-44U's Avatar
ROAR.
AKA: Phil Chang
We tried setting the Watchdog at SetEnabled(0), but still get the same problem. We set it at 0 in the initializers, in autonomous, in the operator function, and in the operator loop. Setting SetExpiration() at an impossibly high number had no success, either.
Unread 19-01-2010, 15:40
1951-44U's Avatar
ROAR.
AKA: Phil Chang
New development!
We tried instigating the Watchdog error while watching the serial output, and found something very interesting.
We could get output from the serial output (meaning that we got the printf values from the code in the serial output) and the sensors were working fine! Outputting data! But once we turned on the target console on the programming laptop (the programming laptop and the serial output laptop are separate laptops) everything STOPPED. Came to a STANDSTILL. No more output, nothing. The serial output stream seemed to FREEZE. That may be why the dog was barking.
But the data we received from the sensors are somewhat strange. The different printf statements mixed and mashed with each other, seeming to overlap. I can't make anything of the data because they overlap so often.
Any ideas?
Unread 19-01-2010, 21:34
AKA: Brad
So when you had just the serial cable plugged in and no target console, was the data reasonable? Is the problem related to having mixed serial output?
Brad Miller
Unread 20-01-2010, 15:37
1951-44U's Avatar
ROAR.
AKA: Phil Chang
I'm not even sure what the data was -- it meshed and overlapped, so the numbers weren't nicely and neatly in line with respective labels.
Example:
______ Turns
______ Position
It was like:
Turns0003054Position
It jumbled all the output.
Unread 20-01-2010, 16:44
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
did you have \r\n at the end of the printf's? this is the new line sequence. if you have printf("part 1") (more code here) printf("part 2 \r\n"), it should output like this:
part 1 part 2
part 1 part 2
part 1 part 2
part 1 part 2
part 1 part 2
part 1 part 2
part 1 part 2
part 1 part 2
part 1 part 2
so you can see 1 and 2 as the numbers fly by instead of
part 1 part 2part 1 part 2part 1 part 2pa
rt 1 part 2part 1 part 2part 1 part 2part
1 part 2part 1 part 2part 1 part 2part 1
part 2part 1 part 2part 1 part 2part 1 pa
rt 2part 1 part 2part 1 part 2part 1 part
2part 1 part 2part 1 part 2part 1 part 2p
art 1 part 2part 1 part 2part 1 part 2par
and you have to do a print screen to look at them
Watchdog.Kill();
Problem receiving console output from cRIO Arborama Programming 7 15-02-2009 03:30
Weird output from ultrasonic and gyro Yuan Xue Lim Programming 4 11-02-2009 19:01
live input/output to/from application MarkH Programming 3 06-04-2006 01:43
Weird Output from Dashboard Port Ian W. Programming 9 06-03-2004 21:33
output from a cell phone? Ben.V.293 Electrical 6 24-12-2003 14:52
