Go to Post The spirit of FIRST lives in all of them[us]. Knowledge is power and the unknown is scarey but in the end the spirit of FIRST will endure. - LSevcik [more]
Unread 16-01-2010, 12:32
Challenger243's Avatar
Challenger243 Challenger243 is offline
AKA: Tyler
FRC #1559 (Deviltech)
Challenger243 is an unknown quantity at this point
Pneumatics v. Motor
What would be more efficient for shooting?
Unread 16-01-2010, 13:27
KGood's Avatar
KGood KGood is offline
Capt'n
AKA: Kevin
FRC #2134 (Aztec Pirates)
KGood is an unknown quantity at this point
Re: Pneumatics v. Motor
Depends on what mechanism you're using...keep in mind pneumatics will take a lot more space, add more weight, and as well have potential for many more problems than a motor...but it also has more capability of storing potential energy if you release the air explosively.
Either way, try to maximize power, initial tests with the soccer ball have shown than they can be a bit tricky to move a long distance; they're a lot denser than the orbit balls we had last year.
2007: Rookie All-Star Award
2008: #2 of 54 in AZ Regional
Unread 16-01-2010, 14:52
etphonehome etphonehome is offline
FRC #0537
etphonehome is an unknown quantity at this point
Mechanisms kicking robots from Overdrive used are a good place to look for shooter ideas.
Unread 16-01-2010, 15:10
AKA: Tyler
we were leaning towards something to flick the ball to get lift or to create front spin, for those what would be beter?
Unread 16-01-2010, 16:49
GaryVoshol's Avatar
Cogito ergo arbitro
Why not set up some prototypes and test what might do what you want?
(since 2004)
Unread 17-01-2010, 11:12
AKA: Tyler
We are I just figured I should see what other teams are going for.
Unread 18-01-2010, 09:29
Tony.Wu Tony.Wu is offline
Carnassial
AKA: Dave The Mechanic
Team Role: Animator
Tony.Wu is an unknown quantity at this point
Send a message via MSN to Tony.Wu
A motor will take time to spin up. While pneumatics will be alot faster. However you must take the recharge rate of pneumatics into consideration.
Unread 18-01-2010, 09:48
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Other teams are doing all kinds of interesting things. I have not seen a consensus on what works best...I've seen a video of a ball hurled very far with a rubber springy type kicker, and another of a ball hurled very far with a pneumatic kicker.
As far as I can tell, the best one to use is the one that YOUR team can make work well!
Unread 18-01-2010, 09:51
Carnassial
Team Role: Animator
And to your size contraints too!
Unread 18-01-2010, 10:33
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
Amen to this. Judging solely by your team number, 1559 has been around for a few years. (Obviously, it may have been idle for a year or more, or have a large number of new members, etc., so "your mileage may vary".) Have you ever worked with pneumatics effectively? Do you have the skills / facilities to do custom machining? And, to some extent, how are your programming skills? These factors will weigh far more heavily for your success on the field than "are motors or pneumatics better?" (After all, if the best solution involves dielectric swizzle sticks, and you've never worked with them, what good is the answer?)
(Being finals week, I have some spare time on my hands. PM me if you want further discussion. Or discuss it here, and all teams can benefit!)
"It's NOT Just A Robot Thing!"
Unread 19-01-2010, 15:22
AKA: Tyler
Thats my problem , the pros and cons are about equal
my main concern is how much power willbe used and which will be beter for shooting.
Unread 19-01-2010, 15:33
Matt H. Matt H. is offline
Long Distance Mentor
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
In my opinion if you can use pneumatics for numerous mechanism then go with pneumatics. Compressed air has a high upfront cost in weight (compressor, tanks, etc), but has a low cost in weight for each additional mechanism (pneumatic cylinders esp. small ones are fairly light).
Motors on the other hand have an essentially fixed weight cost. Each additional motor driven mechanism adds the weight of a motor and the requisite electronics.
As to which is better for a shooter, that comes down to ingenuity. I'm sure there are excellent designs using both and I would make that decision based on how well pneumatics integrate into what you want to do with the rest of the robot.
Unread 19-01-2010, 16:26
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
That all depends on how you use it. Yes, if you're trying to use a motor to spin a kicker directly, you'll have to deal with that. However, if you use the motor to wind up the kicker and hold it in place... the release of that stored energy can be almost instantaneous - even faster than pneumatics, as you have to deal with flow rates and volumes with those. Even better, there are some pretty nice ways to translate the rotational motion of a motor into a linear motion, which can allow you to place the force from the motor away from the center of rotation of your kicker - the additional leverage means you need less torque to push it out, potentially giving you greater speed.
As squirrel said, plenty of videos are out there of teams prototyping. Thus far, i've seen teams be successful with pneumatics, springs, and surgical tubing (rubber tubing that can stretch and hold a lot of energy).
As for what our team is doing... We've been prototyping everything
Unread 21-01-2010, 18:56
AKA: Tyler
Cool Re: Pneumatics v. Motor
we were thinking about winding surgical tubing up with a motor or indirectly using surgical tubing to store energy for a foot or kicker
Unread 21-01-2010, 19:06
yoshibrock's Avatar
yoshibrock yoshibrock is offline
Mechanical Magician
AKA: Brock
FRC #0540 (Talon)
yoshibrock will become famous soon enoughyoshibrock will become famous soon enough
Send a message via AIM to yoshibrock
That's not a bad idea, but now you get to the fun part: designing a release mechanism that doesn't burn out your motor and is safe. Pulling something back and letting go is all fine and dandy, but it's a little harder when you can't use your own hands. It's an engineering challenge if you don't go the easy route and use a transmission/clutch. I'm sure you guys can think of something, good luck!
There is no charge for awesomeness.
Am I a hero? I really can't say, but yes.
Tracking Servo motor with drive motor in Labview mbone206 Technical Discussion 5 28-01-2009 17:32
Motor speed sensing with the Jaguar motor controller? mminutto FRC Control System 5 13-01-2009 18:13
White Paper Discuss: Approx. Motor Spec for Taigene Motor Joe Johnson Motors 2 22-01-2005 16:36
External metal jacket on the Drill motor and FP motor, WHY? archiver 2001 3 24-06-2002 04:22
External metal jacket on the Drill motor and FP motor, WHY? Dennis Hughes Technical Discussion 1 04-06-2001 11:59
