Go to Post To put it simply, its clearly become this. The teams that can score a lot, do well. Rather shocking, isn't it? It doesn't matter if you're a shooter, dumper, power dumper, gravity dumper, spitter, flinger, dunker, shumper, barfer, dropper, or whatchamacallit. Points are points. - Looking Forward [more]
Unread 16-01-2010, 14:23
Sauce Sauce is offline
FRC #1245 (Shazbots)
Sauce is an unknown quantity at this point
Camera + DS Comms
So, we got the DS and the cRIO set up and all of the motors/relays working. We can get the camera to show an image on the Servo Camera Example but the DS just says "Timeout in Camera Communications" and I can't get it to change.
Unread 16-01-2010, 15:45
umangv620 umangv620 is offline
Programming Captain
AKA: Umang
FRC #1403 (Cougar Robotics)
umangv620 will become famous soon enoughumangv620 will become famous soon enough
Re: Camera + DS Comms
we also have the DS and cRIO set up with all of the motors working through ethernet. We have also setup wireless, but we can't seem to setup the camera so that we can view the camera feed in the Dashboard or in LabView. We can get the camera feed by connecting to it using the crossover cable and by accessing it through the IP address.
But when we are trying to get the camera feed in LabView, we are getting error -44003, which says that the cRIO is having trouble communicating/being authenticated with the camera. Is there a documentation somewhere on how we can get it working?
Sorry for invading your post, but I feel as if both of our problems are somehow connected.
Unread 16-01-2010, 16:52
You might want to connect the camera to a computer and check the accounts. Or just run the camera setup Tool. The camera has account authentication, and the WPILib code sends the account info FRC, FRC. If that account hasn't been registered with the camera, I believe that is the error you will receive.
Greg McKaskle
Unread 16-01-2010, 21:36
IceStorm IceStorm is offline
Mentor FRC 5046, FTC 8688
AKA: Chad
FRC #5046 (Jacked Up Jackets)
IceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of light
Send a message via AIM to IceStorm Send a message via Yahoo to IceStorm
we were having the same issue. switched to a custom dashboard and the issue disappeared.
Unread 16-01-2010, 21:43
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
Run the update package to uninstall it, then reinstall it. It worked for us.
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 21-01-2010, 16:25
Andrew0089 Andrew0089 is offline
FRC #3229
Andrew0089 is an unknown quantity at this point
We have got our camera up and communicating with the DS. But we still get the error code 44003. we have the root and frc account on the camera set up. any suggestions?
Unread 21-01-2010, 20:11
Tell us you uninstall, then reinstalled the Driver Station Update?
Does your Dashboard have most of the right side blank?
No comms because of router reset? vivek16 FRC Control System 3 25-08-2009 21:06
No Comms Issue.... JoeyTNT280 FRC Control System 9 11-06-2009 20:32
"No Comms" sabruce01 General Forum 56 09-03-2009 13:50
Tell the difference: 2007 CMU Camera, 2006, 2005 camera? Chris_Elston Programming 2 07-01-2008 13:11
