Go to Post Never quit, never give up, never say die! - Cascade [more]
  #91   Spotlight this post!
Unread 14-01-2010, 09:31
JosephBurns35's Avatar
JosephBurns35 JosephBurns35 is offline
AKA: Joseph Burns
FRC #2487 (Mechanical Animals)
JosephBurns35 is an unknown quantity at this point
Send a message via AIM to JosephBurns35
Re: Effective Drive Base
Joe,
Please be careful in suggesting this or implementing something that violates the robot rules. You can't have metal in contact with the carpet as part of your regular drive design.
this i not what i ment in the sample with woody and dean thay showed the plastic and bunge cord things on the robots by the weals they can also be used as somthing to slide you across the bump to prevent hanging up
  #92   Spotlight this post!
Unread 14-01-2010, 09:48
GaryVoshol's Avatar
Cogito ergo arbitro
Originally Posted by edison View Post
can you tell me how to post cant find it we are registered and all
thanks
Post what, and where? Obviously you've figured out how to post on ChiefDelphi.
(since 2004)
  #93   Spotlight this post!
Unread 14-01-2010, 10:31
brentmcjunkin's Avatar
brentmcjunkin brentmcjunkin is offline
AKA: Brent McJunkin
FRC #0343 (Metal In Motion)
brentmcjunkin is on a distinguished road
Originally Posted by dustinjeremy2k View Post
I'd like to encourage teams to draw lots of diagrams, mock up rolling chassis, and think about the assumptions you are making before designing a "drive base".
Basics
4WD skid - simple, effective, stable climber. If it's designed to stand a chance in a pushing contest, it won't be very maneuverable.
6WD skid / tank tread - a bit heavier, more moving parts, NOT a very stable climber, much more maneuverable, still good at pushing (Usually the best "compromise" chassis, but not this year).
Omni / Holonomic - very versatile, simple, maneuverable, but you're on roller skates, and can't climb well (or at all).
Crab / Swerve - similar to above but with superior traction, superior handling, more complex, many moving parts, not likely to be a good climber. Does not (usually) rotate the chassis efficiently which could lead to more complex (multi-sided) game mechanisms.
I think the best drive systems will be some sort of hybrid between two of the basics. I would NOT use a tread or a crab to climb... good luck to those who try it! (And do you really need to climb anyway?) If you do, you might want to bring a big tool box to the competitions!
Enjoy!
Ok first of all tanks just crawl over cars in war. which means it should be able to go up the ramp. a skid steer would be effective with the right wheels. but i think that the tanks might actually be dominant in this game.
2008 Peachtree Regional Winner 1319 547
2008 Palmetto Finalist 342 393/804
  #94   Spotlight this post!
Unread 14-01-2010, 12:26
trilogy2826's Avatar
trilogy2826 trilogy2826 is offline
Mentor - 2826
AKA: Jake Fischer
FRC #2826 (Wave Robotics)
trilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond repute
thanks
Edison,
I've seen you post this same question in at least four other threads. It is usually bad form to ask the same question multiple times, especially in different threads. I've seen your question was answered multiple times. Are you still having issues?
  #95   Spotlight this post!
Unread 14-01-2010, 13:48
carbuff2228's Avatar
carbuff2228 carbuff2228 is offline
Scouting Mentor -College student
FRC #2228 (Cougartech)
Team Role: Scout
carbuff2228 is on a distinguished road
Originally Posted by Alexis Howell View Post
But if you had a well practiced driver, wouldn't it be easy to avoid other robots with a holonomic drive base? unless of course a couple of robots decided to go into your field area...
Also, rules say a robot can only be pinned for a maximum of 5 seconds.
Also with holonomic, you can just forget about traversing. If it's even important to your strategy.
yeah with meccanum this can help your strategy allowing you to be super manuverable and get away from defensive bots
  #96   Spotlight this post!
Unread 14-01-2010, 19:42
Iceman1330's Avatar
Iceman1330 Iceman1330 is offline
FRC #2523 (Lab Rats)
Iceman1330 is an unknown quantity at this point
It surprising how little conversation there has been here regarding how much a particular drivetrain will limit ball interaction mechanisms.
With a drivetrain which covers an entire side of a robot (6WD, 8WD, tread) you largely lose ability to manipulate balls on that side. (owing to bumper height and ball incursion rules) With a 4WD system (mechanum, holonomic, swerve, or tank with modified CoF) a mechanism can exist on any side of the robot.
To example this I've been mocking up a prototype bot designed to be able to guard the goal.
with 4WD you can park it in front of a goal, raise a shield, and utilize a kicker which extends between the wheels. Should you need to get to the other goal your already oriented to do so. High CoF wheels in the rear provide shoving power and increased turning while the front wheels with moderate CoF keep the robot in a line and add to pushing power. A gearbox + motor for each wheel allows for dynamic power shifting between the different CoF wheel sets.
While much discussion has been devoted to the maneuverability of crab, holo, and mechanum, a 4WD using the kitbot frame,wheel drop downs, and wheels with different CoF (roughtops and modified kit delrins and or rubbers) you should have more than enough maneuvering for most teams. (not to mention the cost and complexity advantages)
With regards to high siding a robot, with a 4WD system and a bottom plate, without any modifications you can and will high side.
However if you install a simple textured drum in the middle of the frame which extends slightly below the skid plate and drive it with a window motor you can effectively crawl to a point where at least one set of wheels gains traction again.
  #97   Spotlight this post!
Unread 14-01-2010, 20:09
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
We tested two of our traditional 6 wheel chassis that preformed very well in '07 and '08. Need less to say, six wheel bots do not like the bump. After fighting just to get on top of the bump, we knocked out a wheel coming back down. So we are going back to the articulating 8 wheel drive that we developed in '04. Hope this helps anyone still designing.
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
  #98   Spotlight this post!
Unread 15-01-2010, 20:37
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
Originally Posted by CraigHickman View Post
I would recommend looking at the WildSwerve (look at the Andymark website) if you're interested in doing a swerve. However, if you aren't confident in the design principles behind a crab, I would not recommend undertaking it this late in the season.
they're out of stock
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
  #99   Spotlight this post!
Unread 15-01-2010, 20:45
joek's Avatar
Originally Posted by Shawyan View Post
(the post he's quoting) Wow. Simply amazing drive train.
I believe the best overall drive train is either full holonomic or Swerve drive. This would allow being able to rotate the robot to face the goal, as well as drive in the desired direction. Swerve drive allow the team to keep more motors free for other activities such as a kicker, but still retain the "any direction i want, i go, no worries".
Also, I do not see the reasoning behind why having smaller wheels will make it more difficult to go over the bump, as long as the wheels are extended further down. Though 4 inches may be pushing it.
and prohibited, unless they posted the designs, due to rule R25, but you could post the CAD files on this thread to make the design COTS
  #100   Spotlight this post!
Unread 15-01-2010, 21:02
Chris is me's Avatar
AKA: Pinecone
What in the quoted post is prohibited?
  #101   Spotlight this post!
Unread 16-01-2010, 14:39
joek's Avatar
the quote of the post i'm quoting
  #102   Spotlight this post!
Unread 16-01-2010, 15:05
whatabouteve whatabouteve is offline
AKA: Dean Keithly
FRC #0245 (Adambots)
whatabouteve is an unknown quantity at this point
Okay Let me explain this. I am from an experienced team that doesn't use swerve drive.
In this game your swerve drive will be destroyed by the sharp angle of the ramp and the load it will be required to carry.
On this note you need to modify the long wheel base to navigate the bump with 2 wheels, however it may be benificial to add an additional wheel to increase the "stuff" you can cram under your chasis.
I really wanted a wide chasis with a 22" wheel base which would serve the same function as a 3rd wheel with a narrow chasis.
The mercana drive thought about will not allow you to easily navigate the bumbs since we have seen this at a local college autonomous competition.
Don't yell at me its just food for thought.
  #103   Spotlight this post!
Unread 16-01-2010, 15:12
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
the WildSwere will not work going over bumps because there is a plate that is about 1" above the ground, and will get stuck on the bump before the wheel can make contact. My team is doing 6wd because of this problem (and our programmer doesnt want to have to figure out a swerve drive in 6 weeks)
-Alex
2010 Washington DC Regional: Engineering Excellence Award
  #104   Spotlight this post!
Unread 16-01-2010, 17:07
Modified modules + modified and creative frame.
  #105   Spotlight this post!
Unread 16-01-2010, 19:47
CraigHickman
Posts: n/a
I never said a Crab would be a good idea, nor that it would make it over the ramp. It would be possible to make a crab that can climb. Heck, it's FIRST! Teams have proven it's possible to make almost anything!
pic: drive base idea dbell Extra Discussion 23 26-07-2008 11:11
pic: DeWalt drive base dbell Extra Discussion 16 18-09-2007 17:10
pic: 195 Drive Base Tom Bottiglieri Robot Showcase 24 16-02-2006 12:50
pic: 1083 drive base CD47-Bot Robot Showcase 11 24-02-2004 14:04
Drive Base Advice archiver 2001 0 23-06-2002 22:57
