Go to Post In the end, you get out of FIRST what you put in. - BlueLipstick [more]
Unread 01-16-2010, 03:01 PM
pafwl pafwl is offline
Franciose
AKA: Frank Larkin
FRC #0272 (Cyber Crusaders)
pafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud of
Default windriver program, no code and warnings on CRIO console out
Have put in all updates I can think of, flashed the CRIO several times with V19. Program compiles with no warnings. Default program .out is created. Download is successful. However power recycle of CRIO produces many warning messages on CRIO console .out serial port. Driver station shows no code. Please help.
Unread 01-16-2010, 04:03 PM
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Re: Default windriver program, no code and warnings on CRIO console out
Check out this thread.
http://www.chiefdelphi.com/forums/sh...threadid=80240
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Logging console data to text file on crio Kingofl337 Programming 3 04-09-2009 06:57 PM
Default Labview Dashboard and Windriver Example Help sircedric4 Programming 7 02-25-2009 01:58 AM
Problem receiving console output from cRIO Arborama Programming 7 02-15-2009 03:30 AM
Problems integrating CMUCAM code and IFI Default Code Windward Programming 2 02-06-2007 04:48 PM
Default Code and printf WilsonDJ00 Programming 2 01-22-2005 04:39 PM
