Go to Post However, the best responses come with patience. It might be a couple of days before you get a good answer or it could be 10 minutes. - Molten [more]
Unread 16-01-2010, 17:07
JohnFogarty's Avatar
AKA: @doctorfogarty
Exclamation cRIO Not Running Code?!?
I am a new programmer and I was using the Getting Started Manual and so I wired the robot and by accident burned out the Analog Breakout board in Slot 1, I know quiite n00bish. anyway I am ordering a new one. I went through the cRIO image tool image tool to set it up for LabVIEW and it completed it right, I rebooted and still all seemed ok. I tried downloading the example Tank Drive hitting run when i open the VI. It loaded the program into the cRIO and it was succesfull. Though when I moved the joysticks nothing happened. Then i discoved the meaning of the Digital Sidecar's LED light..... it was blinking rapid 200ms on 200ms off which in the manual says System error: No driver's station
communication, bad cRIO Image, bad team ID, extensive communication errors. I connected it to the driver station and the robot, and joysticks and everything were green except Robot Code. I had a Vet. of the team look at it and he ran a relay test and said it wasn't getting the code correctly. I tried re-imaging again and rebooting it and still got the rapid LED Blinking. So now i am lost and have no idea. I have tried using 2 computers one being the classmate and the other being my HP Pavilion running Windows 7. HELP HELP HELP!
John Fogarty
Code deploys but does not save to cRIO Bill Taylor NI LabVIEW 11 15-02-2012 20:30
Downloading code: Netbeans does not reset cRIO ellisk Java 8 31-01-2010 19:02
Running the Motors Backward in WindRiver & cRIO Freezes kyungjin C/C++ 15 08-02-2009 14:24
Issue with debugging/running code on cRio 114Klaatu0x72 Programming 5 27-01-2009 14:02
cRIO Not Running Program railerobotics NI LabVIEW 5 18-01-2009 08:48
