Go to Post By the way, safety glasses are so in style now, :) - LightWaves1636 [more]
Unread 15-01-2010, 21:39
unobtainium-42's Avatar
unobtainium-42 unobtainium-42 is offline
Team President
AKA: Eric Eaton
FRC #0670 (Homestead Robotics Team)
unobtainium-42 is an unknown quantity at this point
The download it does nothing
I was pleasantly surprised this year to find that WindRiver (seems to) be working properly. I have some problems that might/might not be related to Wind River.
The sample projects and my alterations compile and the FRC downloader seems properly configured with team number & .out file. When I use download it seems to finish successfully. But when I reset the robot, the code hasn't changed. Any idea why it would do that?
I have also properly configured the camera and connected it to the cRIO but the little yellow light on the Ethernet port does not blink and nothing shows up on-screen. Does the robot code need to activate the camera somehow? If so, the previous problem would keep me from finding out. I know almost nothing about the camera and my teammates want it to align the robot for this year's game
Also, why does the Camera to dashboard example not produce a .out file?
Unread 16-01-2010, 02:07
bradleat bradleat is offline
FRC #1414
bradleat is an unknown quantity at this point
Re: The download it does nothing
I have some of these same problems, although I cannot debug anything either. But some builds don't produce a .out file and the FIRST downloader does nothing. I am going to try a different computer soon
Unread 16-01-2010, 02:15
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
It took me a very very long time and the setup seems to be very fragile, at least to me. For like the first couple hours of hair-pulling, I realized that it was "Downloading To" a localhost connection that you can see in the lower-left corner. I honestly can't recall what fixed it but your first try may be to remove that localhost connection and only have the robot connection. I will try to look in to it more.
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 16-01-2010, 17:54
Team President
AKA: Eric Eaton
I deleted the Local Host but it didn't fix the problem. I did some more work today that seemed to confirm the download wasn't working. I tried to use the Run and Debug configurations, but they terminated instantly and the Robot Code light turned red. Interestingly, when I ran the debugger for one project it stopped in a different one
I agree, the setup is very fragile. Why is it that every year I have to jump through dozens of hoops just to get this thing to work? Is this some sort of plot by the GDC?
Unread 16-01-2010, 17:57
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Did you set up the Remote System as per the C programming Manual? http://first.wpi.edu/Images/CMS/Firs...artedWithC.pdf
Watchdog.Kill();
Unread 16-01-2010, 19:34
garyk garyk is offline
Programming Mentor: 668, 972, 2643
FRC #0668 (Apes of Wrath)
garyk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the rough
Make sure you are downloading the correct *.out file - if you are downloading the same (wrong) one, the symptom will be that the code never changes.
Please see http://www.chiefdelphi.com/forums/sh...0&postcount=19 and scroll down to "But, we're not done" to be sure you are getting the correct file.
Silicon Valley Regional 2005, 2006 972
Silicon Valley Regional 2007 668 Xerox Creativity Award
Championship Event 2007 668
Portland Regional 2008 668
Silicon Valley Regional 2008 668, 972
Beta Test Team 2008 668 (with 100 & 254)
Silicon Valley Regional 2009 668 Regional Chairman's Award; 2643
Sacramento Regional 2009 668 Winning Alliance (thanks, 1717 & 2473!), 2010 Winning Alliance 3256
CalGames 2006, 2007, 2008, 2009, 2010, 2011 Field Tech
NorCal FTC Regional 2008, 2009 Inspector
Championship Event 2009
San Diego, Silicon Valley Regionals; Champ. Event 2010 668, 2643, 3256
Silicon Valley, Madera Regional 2012 2643
WRRF Programming Instructor 2006-2016
Regional Woodie Flowers Award 2014 2643 Utah Regional
Unread 16-01-2010, 23:00
Team President
AKA: Eric Eaton
It was worth a check. Yes, the file path is correct.
Run still does nothing.
I re-imaged the cRIO again and it has no robot code. Let's see if I can change that.
Unread 16-01-2010, 23:32
Team President
AKA: Eric Eaton
I used the C:/windriver workspace with only one project and it works. Auto-completion also started working. Before, I was using a workspace on the D:/ drive.
Run/Debug still halt instantly. Here's the trace from the Console Out:
Break at 0x0219d2c4: FRC_UserProgram_StartupLibraryInit   Task: 0x2217cf8 (tFRC_
UserProgram_StartupLibraryInit)
WPILib was compiled from SVN revision 2069
task 0x218a5c0 (FRC_DriverStation) deleted: errno=0 (0) status=0 (0)
task 0x1d62d08 (FRC_RobotTask) deleted: errno=0 (0) status=0 (0)
!!!   Error: Default code was still running... It was unloaded for you... Please
 try again.
task 0x2217cf8 (tFRC_UserProgram_StartupLibraryInit) deleted: errno=0 (0) status
=0 (0)
Using "Undeploy" first did nothing. What's going on?
Unread 17-01-2010, 09:36
byteit101's Avatar
try again
Did you reboot? there is code running, but you need to reboot between sessions
Watchdog.Kill();
Connecting to cRio, getting the jaguars to go solid yellow.... then nothing. DSST\neal.ian FRC Control System 11 30-01-2009 18:15
The Nothing Thread whytheheckme Games/Trivia 76 08-03-2008 20:20
The brick clicks, nothing else JoeXIII'007 Lego Mindstorm Discussion 3 08-11-2006 18:57
Gaah! Nothing for the animation people! Chris Nowak 3D Animation and Competition 18 05-02-2003 00:22
