Go to Post You wrote a PID control loop for your coach? Whoa. - meatmanek [more]
Unread 16-01-2010, 18:54
Re: cRIO Not Running Code?!?
I tried using the Tank Drive example and could not get it to work either.
It's croaking on the System Watchdog every few seconds.
We may have issues trying to Deploy/Run it from the same machine we are running the Driver Station on.
P.S. I was able to Run the default robot project without trouble, so it seems to be something with the Tank Drive program. However, you have to run the Driver Station program from the Developer account rather than from the Driver account to keep the robot Enabled.
Try picking a program you can "Run as startup" or set it up to do so.
The obvious example is to create a Robot project then Build & Run as startup.
Code deploys but does not save to cRIO Bill Taylor NI LabVIEW 11 15-02-2012 20:30
Downloading code: Netbeans does not reset cRIO ellisk Java 8 31-01-2010 19:02
Running the Motors Backward in WindRiver & cRIO Freezes kyungjin C/C++ 15 08-02-2009 14:24
Issue with debugging/running code on cRio 114Klaatu0x72 Programming 5 27-01-2009 14:02
cRIO Not Running Program railerobotics NI LabVIEW 5 18-01-2009 08:48
