Go to Post 1. If I had a nickel for every time I heard "But we passed at XXXX regional" I would have retired a long time ago. - Al Skierkiewicz [more]
Unread 16-01-2010, 19:50
ellisk ellisk is offline
FRC #1540
ellisk is on a distinguished road
Weird watchdog / dashboard issue
The dashboard often shows that my program "flickers" into "Watchdog" mode periodically while in Teleoperated, either enabled or disabled. This is odd because I have disabled the watchdog both in the constructor and in the Teleoperated mode. Has anyone ever had a similar issue?
Thanks.
EDIT: it also sometimes flickers to the "No Robot Communication" mode.
Unread 16-01-2010, 19:54
TheDominis TheDominis is offline
FRC #2152
TheDominis has a spectacular aura aboutTheDominis has a spectacular aura about
Re: Weird watchdog / dashboard issue
The new driver station is extremely buggy. However, I did have a similar issue when I accidentally had both the old and new driver stations connected to the robot.
Unread 16-01-2010, 19:59
That's a known issue that National Instruments will be looking at.
It may just be the Diagnostics tab on the Driver station.
See: http://www.chiefdelphi.com/forums/sh...threadid=80179
Unread 16-01-2010, 21:10
The driver station isn't supposed to work when two are plugged in trying to control the same robot. I'm pretty sure the blue DS will misbehave under those circumstances too.
If you find issues with the updated driver station, please report them.
Greg McKaskle
Watchdog!?!?!?! NC GEARS General Forum 38 23-01-2010 08:52
Weird issue with the power distribution block X-Istence Electrical 17 08-03-2009 18:32
Watchdog darty NI LabVIEW 8 16-02-2009 09:11
Watchdog Barchechath Programming 6 10-02-2007 20:05
Weird Output from Dashboard Port Ian W. Programming 9 06-03-2004 21:33
