Go to Post ...instead of question marks swirling my mind I got triangles, circles and squares... - Dorienne [more]
Unread 16-01-2010, 19:02
alex42 alex42 is offline
FRC #1072
alex42 is an unknown quantity at this point
cRIO communications problem
Our driver station is completely unable to communicate with the cRIO. Until this morning, the cRIO imaging software was unable to find it, but the Driver account knew it was there. Now the Driver account can't find it either. We checked the wiring, and all we can think of is that someone accidentally shocked the cRIO, which we really hope is not the case.
Unread 16-01-2010, 19:35
Re: cRIO communications problem
Is the power light on the cRIO on?
Are the cRIO Ethernet port 1 status lights blinking?
Is the Robot Status Light on the Digital Sidecar on?
Unread 16-01-2010, 19:52
FRC #1072
Yes to the first two; apparently we haven't attached the robot status light yet though. Either that, or the electronics head didn't understand my question about where it was.
Unread 16-01-2010, 19:57
The cRIO is probably fine then. It's a pretty tough system.
The robot status light is actually built-in to the Digital Sidecar. We attach the big separate robot status light to the Digital Sidecar, and right where it gets attached is an LED that blinks and lights up just as the big light will when you do finally attach it. The big light just makes it easier for you and the Field crew to see.
It should be a blinking LED.
Unread 16-01-2010, 20:14
FRC #1072
Turns out the cRIO got switched into safe mode, and we didn't notice since the switch is tiny and not very clearly labeled.
Unread 16-01-2010, 20:22
Good catch. That is hard to notice.
Problem Configuring cRIO shoffing FRC Control System 5 17-02-2009 08:29
cRio corruption/polling problem nathanww Technical Discussion 1 04-02-2009 23:24
DS and cRIO Not Maintaining Communications Will_Sica FRC Control System 0 10-01-2009 13:39
cRIO Problem Pneumaticsman NI LabVIEW 8 10-01-2009 11:59
cRIO plugin problem gabrielse National Instruments LabVIEW and Data Acquisition 3 18-12-2008 11:30
