Go to Post When a team is a team, anything is possible - Bharat Nain [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 16-01-2010, 16:13
chsrobotics3283's Avatar
chsrobotics3283 chsrobotics3283 is offline
FRC #3283 (Clarksburg Robotics)
chsrobotics3283 is an unknown quantity at this point
Base Plate for Electronics Board Assembly
Was there a base plate for the electronics board included in the kit of parts? If not, then what material should base the electronics board and what size should the base be? I was looking at the Quick Build Template, and I was confused about what size the base plate should be.
Unread 16-01-2010, 17:25
ChazA's Avatar
ChazA ChazA is offline
FRC #0116 (Epsilon Delta)
Team Role: Electrical
ChazA is an unknown quantity at this point
Re: Base Plate for Electronics Board Assembly
There are no defined control board mounting materials provided in the kit.
In the past we have used Lexan successfully. 1/8" is usually good. It is not too heavy, and mounts well. I find wood is a little to heavy unless you find some super light weight stuff.
Do not use metal or carbon fiber. It is conductive and is just asking for shorts... We have made that mistake in the past.
I do not have any good size ideas. Pick out what hardware features you are using, and lay them out on cardboard or something to fins the best sizing.
Unread 16-01-2010, 17:28
Phoenix Spud's Avatar
Phoenix Spud Phoenix Spud is offline
Everyone. Everywhere.
FRC #3132 (Thunder Down Under)
Phoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond repute
My old team used sign board material, it was really lightweight and sturdy. We got scrap pieces donated both years. Just a warning, you need to mount the cRIO on something different because the sign board can conduct electricity.
Sarah Heimlich
Outreach Mentor | Business Mentor
FIRST® TEAM 3132
Unread 16-01-2010, 17:51
How about plexiglass?
Unread 16-01-2010, 19:40
Yuan Xue Lim's Avatar
Yuan Xue Lim Yuan Xue Lim is offline
Electrical Programmer
FRC #3017 (Project Genesis)
Yuan Xue Lim is an unknown quantity at this point
Send a message via AIM to Yuan Xue Lim
plexi glass is cheap but most of the time it is thin. wood might be the best coz it is able to hold a strong amount of weight.
[font="Fixedsys"][b]We Don't Hope We will.
Unread 16-01-2010, 20:09
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
I would strongly suggest that you avoid Plexiglas anywhere on your robot.
Plexiglass runs the risk of shattering, while polycarbonate will just bend.
Many teams make electronics boards out of lexan, wood, or PVC.
P.S. If you didn't know, lexan is just a brand name for polycarbonate.
Unread 16-01-2010, 20:27
Thanks for the suggestion guys, um I was wondering where you could get polycarbonate/Lexan or PVC?
Unread 16-01-2010, 20:39
Chains=Fun
most of our components come from McMaster-Carr http://www.mcmaster.com/# They have a good selection at moderate prices.
I am sure that other teams use different suppliers, but McMaster works for us because we are able to drive to the warehouse and pick up our order the next day.
Unread 16-01-2010, 22:04
CHS,
I am going to add something at this point (for you and any rookies listening). The Crio case is electrically connected to the negative lead of the battery. Therefore the Crio case must be electrically isolated from the robot frame. Lexan makes this easy as Lexan is an electrical insulator. We use punched aluminum sheet and tywraps to secure electronics to the sheet. The sheet can be mounted with pop rivets and a small piece of lexan under the Crio will then provide the electrical isolation.
Unread 16-01-2010, 22:12
Dragon Princess's Avatar
Dragon Princess Dragon Princess is offline
AKA: Katheryne
FRC #3722 (Green wave)
Dragon Princess has a spectacular aura aboutDragon Princess has a spectacular aura about
You can find pretty much a lot of types of Plexiglas or PVC at local hardware stores, my team tends to stick to Home Depot more than anywhere else.
But for loading electrical items its probably best to use some thing non conductible and sturdy (nothing that could break or shatter), and to hold down everything with screws and keep it a safe distance up.
In past years my team has built a little cage to keep the electronics safe, but as long as its further from where the balls can reach, or higher then hitting its self going over a bump your pretty safe as far as placement goes.
From the Dragons to the Green Wave! Make a Splash!
pic: Electronics Board Team2339 Extra Discussion 1 15-01-2009 19:31
ABS Electronics Board Ian Curtis Electrical 3 07-01-2008 23:25
pic: Electronics Base Plate Kris Verdeyen Extra Discussion 7 18-11-2007 20:22
Clear or Plastic Board for Electronics?? D_Price General Forum 3 17-01-2007 10:05
Professional electronics board assembly [annotated collector's edition] Geoff General Forum 7 17-02-2004 21:57
