Go to Post Welcome to ChiefDelphi a month before Kick-Off. This is an annual traditional experience for quite a few regulars. - synth3tk [more]
Unread 13-01-2010, 13:55
TD912 TD912 is offline
AKA: Chris Leung
FRC #1989 (Viking Robotics)
TD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud of
cRIO's Ethernet Port Randomly Disconnecting?
We took apart all the electronics from our 2009 robot (which still works fine), and re-wired everything up to a bare chassis with nothing but 2 motors and camera for testing the new Classmate PC and related software.
However, we can't get the Classmate or any other computer to connect to the cRIO. It doesn't lose power, but ethernet connection seems to randomly turn on and off every few seconds. The LEDs on the ethernet port turn off for a second when this happens.
We're 99.9% sure we wired everything correctly. We already tried different cables and computers. We tried a direct wired tether from the PC to the cRIO. We made sure we were using a freshly recharged battery. The cRIO Reset/Format tool does not function as we can't establish a connection long enough to reset it.
Anybody know what's going on, or how to fix it?
Unread 14-01-2010, 00:08
AKA: Chris Leung
Re: cRIO's Ethernet Port Randomly Disconnecting?
Turned out somehow the power distribution board somehow got damaged after falling off a table and was not sending sufficent amounts of power to the cRIO for some reason. Luckily, we got a another one in the KoP so we wired that up and everything seems to work fine now.
I'll leave this post up in case someone else happens to stumble upon this problem also.
Unread 16-01-2010, 21:30
Chris,
If the PD is from 2009, there is a known problem with a surface mount cap too near the edge of the board. If you dropped it, you may have dislodged the cap and it is now shorting something inside the PD. Try taking the cover off and see if something is loose or floating around inside.
Unread 16-01-2010, 22:42
I wasn't aware of a problem with the Power Distribution board. There was a problem with the Digital Sidecar, C6. Do you have more information about the PD problem?
Unread 17-01-2010, 00:17
Bharat Nain's Avatar
Chris,
Do you know if this problem has been resolved in the 2010 version?
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 17-01-2010, 09:30
I know that there was some work being done at the end of the season. Erik Van Wyk would be the best to ask.
Running Multiple Crio's with one router. Tom Line FRC Control System 1 24-04-2009 14:35
How to prevent broken ethernet port on DS Bharat Nain FRC Control System 32 18-03-2009 11:25
Driver etation ethernet port 2 died! RossC Programming 6 15-02-2009 01:13
RC randomly resets or goes into program mode Tom Bottiglieri Programming 4 15-02-2006 23:32
Encoder counting randomly off by x4 factor jgeorge Programming 5 02-02-2006 21:17
