Go to Post Everyone needs to start working with what they are given, and start appreciating FIRST, not complaining about what they think FIRST is doing wrong. - Marygrace [more]
Unread 16-01-2010, 21:31
ke7qcl's Avatar
ke7qcl ke7qcl is offline
AKA: Byron
FRC #1566 (Ammoknights)
ke7qcl is an unknown quantity at this point
Re: DiscoBots Omni Drive over Bump
Originally Posted by GaryVoshol View Post
Have you considered adding the bumpers to the bot yet? If those are 8" omnis, it looks to me as if the frame member is 12 or 13 inches off the ground. The bottom of your bumper will be no more than 11". Bottoming out?
And a more general question which should be of interest for all teams - what will keep a ball from rolling more than 3" under the frame in this kind of setup?
If they are 8" omnis and the bumpers extend down about an inch it would still leave you with about 4" at the lowest point while crossing the bump, but you still would want to add a type of guard to prevent the ball from rolling under the robot. Some ideas might be either a chain that will flex when you go over the bump or a piece of pvc pipe.
Unread 18-01-2010, 00:18
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Originally Posted by Andrew Schuetze View Post
I too am interested in where, what type, and why they intend to add more wheels are posted by Andrew L.
We plan to add more omni wheels to the front and back to achieve strafing.
We also have lots of testing/cacluations to do with bumpers and speed ratios.
Thanks for all the helpful ideas. We will keep posting videos & updates on twitter. Stay tuned ... http://twitter.com/discobots
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 18-01-2010, 11:15
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Interesting... in 2006 the Toltechs, 499, used just four omni wheels at 45 deg. in the corners to obtain the control you are talking about but we were not able to climb the diamond plate ramp with that set-up. So if I understand your post, you intend to set up a second drive train to give you lateral or side-to-side motion.
I am certian that you are working on dealing with the impacts that the front omni wheel will encounter when hitting the ramp at speed.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 18-01-2010, 14:41
ke7qcl's Avatar
AKA: Byron
you can either do that or instead use mechenam wheels which would be generally the same thing. i think that it would allow you to do the same but i think it would be easier to assemble because they need to be parallel and it would be easier to get over the bump than with 4 omnis at 45 degrees.
Unread 18-01-2010, 16:22
Omnis at a 45 could not climb the diamond plate ramp in 2005. In fact, the plastic versions that where new from AndyMark.biz in 2006 shattered if we hit the ramp too hard. Mechanum wheels where not available from IFI until 2007.
APS
APS
Founder FRC 499
Unread 18-01-2010, 16:59
KGood's Avatar
KGood KGood is offline
Capt'n
AKA: Kevin
FRC #2134 (Aztec Pirates)
KGood is an unknown quantity at this point
Just wondering, on Week 1 Pneumatics Test video where you showed the piston, what PSI were you using?
2007: Rookie All-Star Award
2008: #2 of 54 in AZ Regional
Unread 19-01-2010, 10:16
lynca's Avatar
Andrew Lynch
Our pneumatics test was at 60 PSI
We will try to post more videos of week 2 soon, stay tuned to our new website,
http://2010.discobots.org/node/16
Unread 19-01-2010, 10:19
lynca's Avatar
Andrew Lynch
Thanks for the warning. We have been testing omni wheel high speed impact without any failures yet, but we have our backup wheels ready just in case!
Unread 19-01-2010, 11:18
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
video is not working.......
Faridodin "Fredi" Lajvardi KD7WKD
Unread 19-01-2010, 13:32
DynamiteHack DynamiteHack is offline
FRC #2988
DynamiteHack is an unknown quantity at this point
You guys've already built a robot?? We haven't finished brainstorming!
OT: The more I think about it, the more it seems like using omni wheels in a simple skid-steer config would help this year; can you guys confirm that it skids/sticks less when turning?
Unread 19-01-2010, 21:44
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
To add light on some of the points made in this thread.
Our team has already tested a holonomic omni wheel setup.
As far as going over the bump, the problem we encountered was the transmissions/CIMS bottoming out at the top of the bump.
Raising it or using stilts such as the KOP AM ones raises the COG considerably and that's the route we didn't want to take.
We did additional testing on the 6 wheel setup that you folks proposed and the driver's loved the way they were able to maneuver around the field.
However, using the FP is a bad idea for the drive and we decided to scrap the idea and go now to plan B.
Plan B meaning moving away from omnis and drivetrain setup.
Last edited by waialua359 : 20-01-2010 at 02:06. Reason: further testing verified what doesnt work.
Unread 20-01-2010, 00:51
lynca's Avatar
Andrew Lynch
The videos are just links to youtube & vimeo. The website videos are a bit flaky sometimes. But the kids are working on improving the integrated video section (we usually don't go over 1000 hits) !
http://www.youtube.com/user/lamardiscobots
http://vimeo.com/user1102634/videos/sort:date
Over the bump or under the tower quinxorin Rules/Strategy 44 18-01-2010 14:17
omni drive transmissions gorrilla Technical Discussion 21 27-10-2008 21:17
Omni drive Laaba 80 General Forum 12 25-02-2008 01:56
Lego Omni Drive Synergy1848 Robot Showcase 19 03-01-2007 11:51
omni drive vs tank |20807 61|2|_ Technical Discussion 49 17-01-2006 13:54
