Go to Post I would like to extend my deepest, most sincere thanks to the GDC, for bringing alliances to us in 1999. - Ken Patton [more]
Unread 16-01-2010, 22:39
Mr. A's Avatar
Mr. A Mr. A is offline
Long Live the Fridge
AKA: Mark R Andrews
FRC #3637 (Daleks)
Mr. A has a spectacular aura aboutMr. A has a spectacular aura aboutMr. A has a spectacular aura about
Mecanum wheel size
I searched the threads and couldn't find a discussion on this.
Have any teams out there used both 6" and 8" mecanum wheels that may be able to comment on the pros and cons of the two sizes.
We used AndyMark 6" wheels two years ago and had problems with the side plates deforming, but I know this problem has been fixed with thicker plates. Other than that they were great.
Do the 8" wheels give any better traction on a ramp? Do they handle differently? Better or worse?
I'd appreciate any input. ?:-)
Go teams 3637 & 869[/url]
Unread 16-01-2010, 23:20
alicen's Avatar
alicen alicen is offline
Zebra Committee
alicen is just really nicealicen is just really nicealicen is just really nicealicen is just really nicealicen is just really nice
Re: Mecanum wheel size
we've had experience with both wheel sizes.
we used the 8" for Rack 'n' Roll, and the 6" in Overdrive.
the 8" were great, we had no real issues with them. The 6", we had problems with the plates deforming and digging into the carpet, killing our turn ability completely.
as for your ramp question;
the 8" wheels have no problem with the ramp at all. we tested this extensively today. the robot we were using to test, even realigned itself when we were not perfectly on target
the two different wheel sizes handle differently i'd say (i drove for Overdrive, and had practice with the 8" mech robot). But that's probably more to do with the fact that they're designed differently, and so they function slightly different.
hope that helps
Unread 17-01-2010, 11:24
Mr. A's Avatar
AKA: Mark R Andrews
FRC #3637 (Daleks)
We had the same problem with the 6" wheels for overdrive, but I saw the new wheels at Ramp Riot and the are much beefier. Did anyone use the heavier ones last year for Lunacy?
Would you say one was any more maneuverable than the other?
Did you or anyone else try the 6" on a ramp?
Thanks
Unread 17-01-2010, 11:38
alicen's Avatar
Zebra Committee
well i can't really say that one was more maneuverable than the other because of the issues we had
as for the ramp with the 6", we never tried
Unread 17-01-2010, 13:00
The Megan 2207's Avatar
The Megan 2207 The Megan 2207 is offline
FRC #2207 (Prime 329)
The Megan 2207 is just really niceThe Megan 2207 is just really niceThe Megan 2207 is just really niceThe Megan 2207 is just really nice
[quote=Mr. A;900980]We had the same problem with the 6" wheels for overdrive, but I saw the new wheels at Ramp Riot and the are much beefier. Did anyone use the heavier ones last year for Lunacy?
I doubt anyone used mecanum wheels at all for Lunacy. Those slippery plastic ones were required for all robots.
Unread 17-01-2010, 14:42
Mr. A's Avatar
AKA: Mark R Andrews
FRC #3637 (Daleks)
[quote=The Megan 2207;901016]
Duh, My bad..... ?:-P
8 years of this can turn your head to mush. I'll have to engage my brain before I post next time!
So this is the first year for testing the new model. Any preliminary results?
Unread 17-01-2010, 14:58
yoshibrock's Avatar
yoshibrock yoshibrock is offline
Mechanical Magician
AKA: Brock
FRC #0540 (Talon)
yoshibrock will become famous soon enoughyoshibrock will become famous soon enough
Send a message via AIM to yoshibrock
We were looking on andy mark and found these monsters http://andymark.biz/am-0298.html
Too bad they weigh 14 pounds each and cost $710 a set.
Anyways, from what I've seen around here (vids and such) it looks like 8 in. mechs are not gonna have too much trouble getting over a bump, as long as you build up a decent amount of speed. As for mechanical integrity, we've used 8 inchers in the past without too much trouble, but after 3 years the plates are starting to deform. I think they should be fine for competition, but you might want to buy two sets. I have no experience with 6 in. mechs though, sorry.
There is no charge for awesomeness.
Am I a hero? I really can't say, but yes.
Unread 18-01-2010, 08:58
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
Well, we should know if the 6" can climb shortly. We have the 6" in house now, and we'll be building up the drive train this week. We know the 8" work, because we have some. If the 6" don't work, we can always swap in the 8" ones in relatively short order.
Brian Graham
pic: Vex Mecanum Wheel Chuck Glick Extra Discussion 19 18-01-2013 10:47
Mecanum Wheel Considerations abross General Forum 20 23-01-2010 19:34
pic: New mecanum wheel? scottydoh Extra Discussion 5 16-01-2010 21:29
pic: 2" Mecanum Wheel Tytus Gerrish Technical Discussion 17 22-04-2006 12:22
pic: Micro Mecanum wheel Tytus Gerrish Extra Discussion 6 12-05-2005 23:20
