Go to Post The best way to brainstorm is to just do it. - EricH [more]
Unread 16-01-2010, 15:16
mcristina444 mcristina444 is offline
FRC #2078 (Robotic Ooze)
mcristina444 is an unknown quantity at this point
Exclamation cRIO HELP!!!
My team is not a rookie team so we have the cRIO from lat year. we decided not to use the classmate from devolpment. So we installed labview to a separate computer.we try to connect to the cRIO through the imaging tool but it can never find it. we have tried both crossover cables and straight cables but each time it can not find it. Any one elese have this problem?
Unread 16-01-2010, 17:33
Re: cRIO HELP!!!
Be sure to turn off firewalls and disable any other networking interfaces such as wifi.
Greg McKaskle
Unread 16-01-2010, 17:41
alex42 alex42 is offline
FRC #1072
alex42 is an unknown quantity at this point
Re: cRIO HELP!!!
We're having the same problem. If I find a solution, I'll tell you.
Unread 16-01-2010, 20:02
FRC #1072
Re: cRIO HELP!!!
Also make sure that the cRIO isn't in safe mode. In that case, the DS won't be able to find it.
Unread 16-01-2010, 20:09
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Re: cRIO HELP!!!
Just a thought....make sure your computer's IP address is set up to
10.XX.YY.ZZ
where XX and YY are a four digit team number (with a leading zero if necessary) and ZZ is any unused address on the network.
Unread 17-01-2010, 04:51
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: cRIO HELP!!!
Also make sure you don't have any other network interfaces such as wireless adapters enabled.
Unread 17-01-2010, 14:28
aeasson aeasson is offline
FRC #2435
aeasson is an unknown quantity at this point
Re: cRIO HELP!!!
Be sure to check firewall status.
I had the probem you are describing and had to turn off the windows firewall.
Crio Help GillSt.Bernards FRC Control System 1 15-02-2009 00:00
Need help with CRIO GillSt.Bernards Electrical 4 14-02-2009 14:42
CRIO HELP!!! lordsoze Technical Discussion 8 07-02-2009 08:48
Dead cRIO??!!? HELP!!! naruto137 Technical Discussion 11 05-02-2009 23:58
cRio IP change help mastergamer1231 Programming 1 03-02-2009 19:38
