Go to Post CIMs are NEAR indestructible and I <3 them for it. - Andrew Schreiber [more]
Unread 16-01-2010, 14:31
Ice Berg's Avatar
Ice Berg Ice Berg is offline
Seth Berg
AKA: Seth Berg
FRC #0694 (Stuy Pulse)
Ice Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to behold
Send a message via AIM to Ice Berg
Plaction Wheels : 250 Spacers/Review
Hey,
I have two questions regarding the AndyMark plaction wheels:
First: Does one need to use the 250 plastic spacer (http://store.andymark.biz/am-0207.html) to mount a sprocket to the plaction wheel? It doesn't specifically say so anywhere, but 2 of these spacers are included in the AndyMark drive systems that use plaction wheels, so I wanted to make sure.
Second: Has anyone had any problems with these breaking. I know a few teams broke last year's rovers wheels, and those were made of the same molded polycarbonate, but were under lower force without the friction of carpet. Any general reviews would be great.
Thanks,
-Seth
Mens et Manus
Unread 17-01-2010, 09:21
richwong richwong is offline
None #1701 (Robocubs)
richwong is an unknown quantity at this point
Re: Plaction Wheels : 250 Spacers/Review
We're using the plaction wheels. If you use the kit sprockets (22 tooth, if i recall), you'll either need to use the spacers or turn down the hub of the wheel on a lathe for there to be enough room for the chain the seat fully. If you're using a larger sprocket, you should be fine without the spacer.
Unread 17-01-2010, 11:26
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
I haven't heard of anyone having problems with the plaction wheels breaking. As far as I know, the part that some teams kept breaking on the rover wheels was the acetal tread, which is different from polycarbonate.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
PVC Spacers fhsteam613 Kit & Additional Hardware 3 08-01-2009 22:38
andy mark plaction wheel gorrilla Technical Discussion 2 05-10-2008 15:25
Axles/Spacers neoshaakti Technical Discussion 6 10-01-2008 13:56
Spacers srjjs Kit & Additional Hardware 6 13-01-2004 20:49
Spacers in FIRST gearboxes Dr.Bot Motors 11 02-02-2003 20:49
