Go to Post A well-designed shifting transmission, controlled by an experienced driver (or a clever bit of software), is an advantage. - Alan Anderson [more]
Unread 17-01-2010, 13:46
IamMisplaced's Avatar
IamMisplaced IamMisplaced is offline
Newbie Coach
AKA: IamMisplaced
FRC #2458 (Team Chaos)
Team Role: Driver
IamMisplaced is an unknown quantity at this point
Exclamation Robot Design: Frame Perimeter?
We are wondering, the rule, and revision to the rule, is relatively vague about what constitutes a frame perimeter. We are design a "snow plow" directly into our robot, but if the balls go into that plow, is that considered inside the 3" perimeter rule? Or, does that only mean literaly under the robot?
Unread 17-01-2010, 13:55
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Robot Design: Frame Perimeter?
I can't say; I think the rule is pretty clear:
FRAME PERIMETER – the polygon defined by the outer-most set of exterior vertices on the ROBOT (without the BUMPERS attached) that are within the BUMPER ZONE. To determine the FRAME PERIMETER, wrap a piece of string around the ROBOT at the level of the BUMPER ZONE - the string describes this polygon
Got any string?
If any ball can go more than 3" inside that string, it's not allowed.
Unread 17-01-2010, 13:57
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
It might help if you show us some drawings of your planned robot design. I don't really understand your description.
Show the robot from a couple different views, or an isometric drawing.
Unread 17-01-2010, 14:05
Newbie Coach
AKA: IamMisplaced
Team Role: Driver
The thing is, with the string thing, what if there is a gap? Imagine an H, does that include the inside parts of an H?
Unread 17-01-2010, 14:09
MrForbes's Avatar
AKA: Jim
The string goes across the gap, so the FRAME PERIMETER also goes across the gap. But the bumper rule says you need to protect both sides of any outside corner with bumpers. Basically you cannot have a notch in your bumpers.
There have been a few threads discussing this already.
http://www.chiefdelphi.com/forums/sh...ad.php?t=79945
Unread 17-01-2010, 14:14
Newbie Coach
AKA: IamMisplaced
Team Role: Driver
BUT, what about revised section <R19>, and in effect diagram 8-5, it only says the robot frame, which is within the bumper, and why can't the frame be something but a perfect polygon and no inlets. Also, in the other forum, they said that it would be legal because the bumper is covered by everything and the balls wouldn't be inside the robot.
Unread 17-01-2010, 14:17
GaryVoshol's Avatar
Cogito ergo arbitro
The entire bumper length must be backed up by frame members. (<R07>) That's why there must be a complete frame all around the FRAME PERIMETER.
(since 2004)
Unread 17-01-2010, 15:03
MrForbes's Avatar
AKA: Jim
It would be very helpful to see drawings of what you're trying to do.
Frame Perimeter x Bumpers sloteera Rules/Strategy 8 14-01-2010 11:18
Frame Perimeter? jimbot General Forum 2 10-01-2010 13:48
pic: Frame Design Shira Extra Discussion 10 01-02-2009 14:06
Holding of Game-Pieces Outside the Robot Perimeter MikePres General Forum 2 24-01-2009 07:21
pic: 1305 Frame design with trannies CD47-Bot Robot Showcase 19 25-09-2004 01:13
