Go to Post FIRST should come with a warning label. - Tim Sharp [more]
Unread 17-01-2010, 14:21
JimC2550 JimC2550 is offline
FRC #2550
JimC2550 is an unknown quantity at this point
Log out of Developer to use DRIVER STATION?
Got the FRC Basic Robot Framework and some examples to work with new Driver Station. ONLY by starting LabVIEW code in Developer log on, then switching users to DRIVER and then clicking on ENABLE
But if I try to exit to go back to LabVIEW on the DEVELOPER log in, the Driver Station is no longer Enabled.
Is there a way to keep the Driver Station ENABLED and go back to the LabVIEW program so that debugging can take place.
It sure seems like I am missing something... it does not make much sense to operate this way.
Unread 17-01-2010, 14:37
Re: Log out of Developer to use DRIVER STATION?
Personally, I would not want to use the classmate as my main development PC. The keyboard and the screen are tiny.
My preferred way to develop is to run the classmate in the driver user, and run LabVIEW on my own computer.
Alternately, you can run both LabVIEW and the driver station software on the development user
Unread 17-01-2010, 14:52
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Well, you should be able to run the driver station in the Developer Account.
It can be found in the program menu.
-- Marshal Horn
Unread 17-01-2010, 22:01
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Just make sure you DON'T use the "Switch Users" feature... this will result in the Driver Station application running on both the Driver account and the Developer account. The end result is that it won't be able to communicate with the robot.
2010 Driver Station Netbook Driver Account and Java joshholat FRC Control System 2 10-01-2010 15:04
Driver station... the man Control System 16 06-01-2010 21:06
Driver Station dnrobotics11 Control System 2 18-02-2009 21:35
Driver station window blanks out? Tom Line FRC Control System 2 21-12-2008 09:31
Can't log out correctly for some reason Adam Y. CD Forum Support 2 12-05-2004 21:19
