Go to Post FIRST is our Hunger Games. May the odds be ever in your favor. - GeorgeM [more]
Unread 17-01-2010, 14:17
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: pic: 2010 window motor winch
I have to agree with Tom about the great explanation from Joe, but, show some mercy on a software guy and explain the formula use to calculate the 54W below.
TIA
If you are trying to lift a 120lbs motor 3ft in 10 seconds -- that means you need 54 Watts. If you only have 40Watts (the best you can do with 2 window motors at 12V) then you are not going to do that much work (lifting the robot that high) in that amount of time... ...no matter how you gear things...
Unread 17-01-2010, 14:37
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
TIA
I'll take a shot at it. Work = Force*Distance. Power=Work/Time. So, say we are trying to lift 120lb to a height of 3 feet. Then you need to do 360lbf-ft work to it. To do this in 10 seconds, you need 36lbf-ft/sec of power. There are 550lbf-ft/sec in one Horsepower. There are 746 Watts in one horsepower. So, you need about 49 Watts to make this pull. If you consider the force required to accelerate the robot from zero to loaded-line-pull speed, and inefficiencies and whatnot, more power will be required.
Unread 17-01-2010, 14:46
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
TIA
Here's one way I came up with 54W:
120lbf * 3ft = 488 J (Work = Force*Distance, there's a conversion factor from lbf-ft to J in here as well. Google Calculator did this conversion for me)
488J/ 10s = 48.8W (Power = Work/Time)
48.8W / .9 = 54 W (Gearbox efficiency)
From what I remember reading here and erring on the side of caution I would use 80% as the gearbox efficiency yielding 61W of power necessary.
Also be careful using 120lb as a weight. A full 120lb robot this year could end up at over 150lb after adding battery and bumpers. Using 150lb and 80% efficiency you need about 76W of power to complete the lift in that time.
Unread 17-01-2010, 14:50
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
But you have to account for the bumpers and batt
Every day is a new adventure!!!
pic: Vex Winch AdamHeard Extra Discussion 5 16-11-2006 23:30
pic: Sprocket mounting for window motor team222badbrad Extra Discussion 3 22-02-2005 03:06
pic: Team 1293's Window Motor Drivetrain 2 Billfred Robot Showcase 18 03-02-2005 23:33
pic: Team 1293's Window Motor Drivetrain 3 Billfred Robot Showcase 0 03-02-2005 21:20
need window motor pic!! Rickertsen2 Motors 3 04-02-2003 21:50
