Go to Post If you want to prove your worth, prove it by creation, not destruction. - DanL [more]
Thread Tools Rating: Thread Rating: 2 votes, 4.00 average. Display Modes
Unread 17-01-2010, 15:29
ionine_ ionine_ is offline
FRC #0334
ionine_ is on a distinguished road
Math.atan2 ?
Hello. This year my team is planning to use Mecanum wheels, and we are programming in Java. Since we plan to use RobotDrive.holonomicDrive, we need to convert joystick (Xbox controller, and some of the axes are inverted so WPILibJ's Joystick.getMagnitude, etc. are out of the question) and our algorithm for this involves Math.atan2. However, the JRE on the cRIO doesn't seem to have such a feature. Is there any way to forgo using Math.atan2 or is there some other replacement for converting Cartesian coordinates to polar coordinates?
Thank you,
Ilya Ostrovskiy, #334.
Unread 17-01-2010, 16:01
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
Re: Math.atan2 ?
Look in the package com.sun.squawk.util.MathUtils for extra math functions.
static double acos(double a)
Returns the arc cosine of an angle, in the range of 0 through pi.
static double asin(double a)
Returns the arc sine of an angle, in the range of -pi/2 through pi/2.
static double atan(double a)
Returns the arc tangent of an angle, in the range of -pi/2 through pi/2.
static double atan2(double y, double x)
Converts rectangular coordinates (x, y) to polar (r, theta).
static double exp(double a)
Returns Euler's number e raised to the power of a double value.
static double expm1(double a)
Returns ex -1.
static double IEEEremainder(double x, double p)
Computes the remainder operation on two arguments as prescribed by the IEEE 754 standard.
static double log(double a)
Returns the natural logarithm (base e) of a double value.
static double log1p(double a)
Returns the natural logarithm of the sum of the argument and 1.
static double pow(double x, double y)
Returns the value of the first argument raised to the power of the second argument.
static double rint(double a)
Returns the double value that is closest in value to the argument and is equal to a mathematical integer.
static long round(double a)
Returns the closest long to the argument.
static int round(float a)
Returns the closest int to the argument.
static double scalbn(double x, int n)
performs x*2^n by exponent manipulation
(By language specification rules we aren't allowed to add non Java ME methods to the java.* package).
Unread 17-01-2010, 16:03
FRC #0334
Re: Math.atan2 ?
Thank you very, very, much!
Unread 23-02-2010, 23:38
Geek 2.0 Geek 2.0 is offline
FRC #0107
Geek 2.0 will become famous soon enough
Re: Math.atan2 ?
Any reason why they didn't include the java.lang.Math ones? They really didn't include many in there...
Unread 24-02-2010, 14:52
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
Re: Math.atan2 ?
The CLDC was designed to target devices without a lot of resources, like cell phones. The extra Math functions weren't necessary.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 25-02-2010, 00:09
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
Re: Math.atan2 ?
Team 20 used some fancy calculus and made our own atan2 function, using a taylor series
Unread 25-02-2010, 11:07
ericarseneau ericarseneau is offline
ericarseneau is an unknown quantity at this point
Re: Math.atan2 ?
Unfortunately to be able to call this Java, we had to follow a specification that defines EXACTLY what classes and what methods exist on classes in the java.* and javax.* packages. For the Java that this VM implements, CLDC 1.1 and IMP 1.0, these functions dont exist.
The spec however, allows us to do whatever we want in OEM extensions, ie in other packages. So we added some of the functionality that we fealt was missing.
Its annoying, but it is what it is.
Tetra Math ZZII 527 General Forum 34 22-01-2005 14:13
A math haiku mtrawls Chit-Chat 0 11-03-2004 20:22
math.h library mightywombat Programming 24 17-01-2004 13:10
Math Hermione692 Chit-Chat 15 21-02-2003 10:47
Math Help!!! Leon Machado IV Chit-Chat 7 16-11-2001 19:38
