Go to Post Don't take my questions negatively, I just hold drive trains to a ridiculous standard. - AdamHeard [more]
Unread 17-01-2010, 17:02
Dark_Vizior Dark_Vizior is offline
FRC #3257
Dark_Vizior is an unknown quantity at this point
Re: Problem with the comunication - camera and cRio
Hey,
We (team 3257) are getting the same -44003 error when connecting the camera to the cRIO. We can access the camera with a web browser on the other side of the wireless bridge, however, we cannot access it when it is connected to the cRIO.
We added a hub between the wireless bridge and the RIO and we are monitoring the traffic with a packet sniffer. When the camera is attached to port 2 of the cRIO, the only traffic we see are SYN packets being sent from the cRIO address to the camera address. The camera never sends back ACK packets.
Any help? That'd be great.
Unread 17-01-2010, 17:57
Promise me you're running the correct Dashboard as in picture 1 above.
That's got to be the #1 trap people are falling into.
The cRIO doesn't act as a router, so you won't be able to sniff the camera response back to the cRIO from a hub attached to port 1, just the cRIO's messages to the camera. You'd probably see them if you were attached to port 2.
Since the cRIO isn't a router you can't communicate through the cRIO to the camera as it's on a different net (192.).
So what you are getting seems normal and what I'd expect to see.
A secondary issue is not having the camera username/password accounts the cRIO is using (FRC/FRC).
Problem with cRIO Imaging Tool Doc Wu FRC Control System 7 15-12-2009 19:47
2009 Camera and Jag inventor models problem Creator Mat CAD 5 08-03-2009 14:05
Axis camera without the cRIO CrazyCarl461 NI LabVIEW 12 17-01-2009 10:53
Who is Programming the cRIO with C++ and what success are you having? Wayne C. Programming 20 01-01-2009 16:48
Having a little problem with the camera... capenga Technical Discussion 3 21-01-2005 10:54
