Go to Post FIRST is again mirroring real life. And in real life, when we build and design robotic and automated systems, it's safety first. Hitting a human in real life loses a lot more than 30 points. - Fred Agnir [more]
Unread 17-01-2010, 10:23
GX67 GX67 is offline
AKA: Wesley Jen
FRC #2554 (JPS Warhawks)
GX67 will become famous soon enough
Send a message via AIM to GX67
Need some help with possision of the ball.
We've been having some problems deciphering the rules that apply to the holding of a ball, and the bumper zone.
This is a link to our current chassis: Click here.
The 12"x12" (tentative) zone to the right of the image is the place where we're thinking of herding the ball, and having two 6" diam. wheels from Overdrive as the rollers for the ball. They'll be put at an angle, each perpendicular to the other, to brush the ball and allow for the ability of herding a ball and then shooting it out.
The trouble is, we're not sure of what is defined as the "Bumper Zone" in our case, and therefore have no idea as to whether or not we are allowed to have the wheels in position in the first place.
So the question is this: Would we be allowed to have anything like a roller to brush/roll the ball around, and if so, what would be the allowed height?
Any help with that question would be greatly appreciated.
*Note: The two wheels will be at ~45 degrees, and the axle will be about 10" off the ground. The wheels will be pushing down on the ball slightly from above.
FRC - Head Photographer, Mechanical-subteam Captain, and Webmaster
Unread 17-01-2010, 14:28
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Need some help with possision of the ball.
Have you read rules <R19> and <G46>? The 12x12 area is a severe violation of those rules of ball penetration of your FRAME PERIMETER.
Also to comply with <R07-M> and Figure 8-3, you have to have a solid part of your frame behind all bumpers.
(since 2004)
Unread 17-01-2010, 15:01
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The BUMPER ZONE is defined as the volume of space between 10" and 16" above the floor. It has nothing to do with the shape of your robot frame.
The FRAME PERIMETER is the area defined by the outside corners of your robot. The ball can't go more than 3 inches inside your FRAME PERIMETER. So you don't want a 12" deep notch in your robot frame below the BUMPER ZONE (that is, the bottom 10 inches of your robot)
Unread 17-01-2010, 17:29
AKA: Wesley Jen
So if I understand you correctly, they're defining the frame perimeter as the rectangle formed by the four corners of the robot, and we can't have an alcove like the one formed? Even if we have the bumpers extend on the three sides inside?
Unread 17-01-2010, 17:34
Bumpers have to be on the frame perimeter; there are several points in <R07> that require that.
You can have the alcove, provided that it is NOT in the frame perimeter and that the ball goes no further than 3" into the frame perimeter.
Unread 17-01-2010, 17:39
AKA: Wesley Jen
Ah, got it. So I guess we're going to have to think up of a different sort of system to hit the ball.
Unread 17-01-2010, 19:01
GaryVoshol's Avatar
Cogito ergo arbitro
Remember that the ball will fit underneath your bumpers, and plan accordingly.
(since 2004)
I need some help with programming the Pneumatics DPTeam270Driver Pneumatics 1 01-05-2008 18:58
Hi, I need some help with the MPLAB IDE... razer Programming 9 04-01-2007 07:47
Need some help with a ball launcher amateurrobotguy General Forum 5 05-02-2006 21:04
need some help with the OI, and wiring a display pryoplasm Control System 8 10-03-2004 20:46
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
