Go to Post Never underestimate the power of human ingenuity. - Wetzel [more]
Unread 01-17-2010, 05:56 PM
charlie1218 charlie1218 is offline
FRC #1218
charlie1218 will become famous soon enoughcharlie1218 will become famous soon enough
Re: Steel Frame
1218 has been using 8020 since our second year and it has been wonderful to us. While we could do a welded aluminum frame, we often find ourselves making HUGE changes in the end of the build season. Plus, it provides so much flexibility and is easily reusable and i is easy to prototype with. We have learned the art of lexan, 8020 and luan (where needed). Its all about what fits your needs, and we have some crazy ideas that wouldn't work without 8020
Unread 01-17-2010, 06:03 PM
mark johnson's Avatar
mark johnson mark johnson is offline
FRC #3175 (knight vision)
mark johnson has much to be proud ofmark johnson has much to be proud ofmark johnson has much to be proud ofmark johnson has much to be proud ofmark johnson has much to be proud ofmark johnson has much to be proud ofmark johnson has much to be proud ofmark johnson has much to be proud ofmark johnson has much to be proud of
Re: Steel Frame
Originally Posted by silv940 View Post
I don't understand the question
Normalizing in simple terms is post heating the weld to relieve stress from the weld process. Actually when you weld chrome moly tube you should pre and post heat the weld joint but i know alot of chassis builders that do not and have no problem. Another way you can normalize the frame is to totally finish the frame , drill tiny holes by each weld joint and have the whole frame heated in a oven , this will take out all stresses built up by the welding process.
K.I.S.S.
Unread 01-17-2010, 11:36 PM
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Steel Frame
thanks for explaining that
Did some more welding. The transmission and chain tensioner mounts are welded to the top of the frame, the axles to the bottom. Center four axles are welded to 1/8" thick plate, the plate is welded to the frame, to drop them down a bit for easier steering.
Unread 01-18-2010, 09:31 AM
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Re: Steel Frame
I must admit I'm a little confused...Why add unnecessary weight? Just because you can't weld aluminum doesn't mean you shouldn't use it. Rough estimates would say steel is about 3 times the weight of an equivalent piece of typical aluminum. So with 1/16 inch wall steel, and 1/8 wall aluminum you have half as much volume with the steel. So for a size that would weigh 16 pounds in aluminum, the same volume will weigh 24 pounds in steel. Do you really want to waste that much weight into a frame that's strength would suffice in something that is much lighter. Plus the fact that you can also use 1/16 aluminum in places of low contact. My team used half 1/8 aluminum and half 1/16 and we never had any problems at all. True we welded it, but there are certainly ways to bolt aluminum that are very structurally sound and are still much lighter than welded steel. It's your call though. There are some advantages to steel as you mentioned, but I don't think the added weight is worth it.
Unread 01-18-2010, 09:32 AM
MrForbes's Avatar
AKA: Jim
Re: Steel Frame
The assembly shown has support for the wheels and transmissions, and weighs under 12 lbs.
If that's too heavy for your robot, then you should definitely use something besides steel!
Unread 01-18-2010, 12:02 PM
Dick Linn's Avatar
no team (Synergy)
Re: Steel Frame
Jim,
For this particular configuration, I don't blame you for using steel. The stiffness:weight ratios of steel and aluminum are pretty close. They you have to consider the section. Plus, it's a lot easier to weld steel axles on steel tube.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 01-18-2010, 03:00 PM
Re: Steel Frame
Jim,
We have used steel in the past. One of the drawbacks was the ability to rework in the pits. It's tough to drill speed holes in the steel frame to loose weight and drilling takes more time when you need to mount something. If you have the weight, which this year's game seems to allow, then you should have a workable frame.
Unread 01-18-2010, 04:05 PM
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Re: Steel Frame
8020 can be a great frame material also.
The key is to make sure connections are tight and stay tight.
Some nylon insert screws, or the removeable locktite is a good solution.
Every material choice has pros and cons - the key is to determine your specific needs and capabilities, and make the best of your choice - whichever material that is.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 01-18-2010, 05:15 PM
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
Re: Steel Frame
Not exactly. I believe (don't hold me 100% to this, I am only in 1st year material science), the most important characteristic for a FIRST robot framing material is the specific stiffness [Elastic Modulus (willingness of the material to bend)/ Density]. Steel and Aluminium are pretty much equivalent in this regard. Still, you can get a more durable frame out of aluminium, for equivalent weight.
If you have the weight to spare, it is a cheaper (and easier to fabricate) solution, and cost is a real world parameter that many teams have to deal with.
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
Unread 01-18-2010, 06:20 PM
Steve Kaneb's Avatar
Steve Kaneb Steve Kaneb is offline
I like two Championships, AMA!
AKA: Alex
FRC #0190 (Gompei and the H.E.R.D.)
Steve Kaneb is just really niceSteve Kaneb is just really niceSteve Kaneb is just really niceSteve Kaneb is just really nice
Send a message via AIM to Steve Kaneb
Re: Steel Frame
That's what brazing is for. 190 has parts from our '99 swerve drive that are brass->steel, and they've held up remarkably well. Brazing is also excellent with aluminum->steel.
WPI District 2016 Volunteer Coordinator.
2016 Referee: NE Granite State, NE UMASS Dartmouth, NE Rhode Island, NE Boston, NEDCMP
Unread 01-18-2010, 06:48 PM
billfunk29 billfunk29 is offline
FRC #3042 (Constant)
billfunk29 is an unknown quantity at this point
Re: Steel Frame
We have a prototype steel frame. 1x1x16ga.
No test data yet.
Check out Wellnuts for attaching things.
http://www.hansonrivet.com/w71.htm
We are also using a Flowdrill for tapped holes. My 1.5hp bridgeport will work a 10-32 flowdrill, if I spot heat with a torch just before drilling.
To get equal durability from aluminum we would have had to heat treat after all the welding. Didn't seem practical.
Unread 01-18-2010, 07:56 PM
MrForbes's Avatar
AKA: Jim
Re: Steel Frame
Thanks for the comments, they are all appreciated.
I put the bare frame (as shown in the photo in my previous post on the postal scale in the shop...10.5 lbs.
We worked today on figuring out how the ball handling mechanisms will fit, and will probably add an upper frame made of the same steel tubing, which will add about 12 lbs, for a total frame weight of under 24 lbs. This is about the same as last year's plywood robot. I think we're doing OK, since we don't see how we can get much weight in the mechanisms this year. I guess if you have 80 lbs of stuff "on top" then the extra 5(?) lbs that steel adds would be a problem.
Unread 01-20-2010, 03:06 AM
MrForbes's Avatar
AKA: Jim
Re: Steel Frame
latest update. We added the top of the frame, which forms the surface that will support the bumpers. It will also support the kicker at the front, and probably some other stuff like an arm if we ever figure out what that is.
I think it should weigh right around 21 lbs as it sits. If you don't like the material, perhaps the design, done in aluminum, might work for you?
Steel Frame? gburlison Technical Discussion 20 12-18-2007 04:56 PM
Welding stainless steel to mild steel... can it be done? Travis Covington Technical Discussion 3 01-27-2004 07:11 PM
Steel Blends Wetzel Technical Discussion 2 09-15-2003 05:01 PM
steel tubing BBFIRSTCHICK Rules/Strategy 2 01-14-2003 10:03 PM
Steel Edge AJ Howard Rules/Strategy 1 01-18-2002 06:52 PM
