Go to Post [You know you've overdosed on FIRST when...] When you discover that the cure to the swine flu is "oink oink BOOM!" - Katie_UPS [more]
Unread 17-01-2010, 15:27
camper365 camper365 is offline
FRC #1599
camper365 is an unknown quantity at this point
Program C++ in NetBeans?
Is it possible to use NetBeans to program the robot in C++?
The issue is that I am running Linux and having problems getting WindRiver installed and would like to use NetBeans to write and test code. I have been able to successfully install NetBeans but not Wind River so I would like to use that.
Unread 17-01-2010, 15:43
rogerlsmith's Avatar
rogerlsmith rogerlsmith is offline
Software Engineer
AKA: Roger Smith
FRC #3357 (COMETS)
rogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to behold
Re: Program C++ in NetBeans?
As far as I know, Java is the only FRC supported language for development in NetBeans.
Roger Smith
Mentor - FRC Team 3357
COMETS - Creating Outstanding Minds, Embracing Technology & Science
Share FIRST videos, photos and experiences at FIRSTObjective.org
Unread 17-01-2010, 16:02
FRC #1599
Is there an unsupported way to do it?
Unread 17-01-2010, 16:14
Software Engineer
AKA: Roger Smith
FRC #3357 (COMETS)
Not sure, but doubtful. I think it'd be a bit of a risk to spend time right now investigating the feasibility of this. Maybe something you'd want to look into after this season is complete.
Roger Smith
Unread 17-01-2010, 16:16
svenw svenw is offline
FRC #3683
svenw is a jewel in the roughsvenw is a jewel in the roughsvenw is a jewel in the rough
are you using linux to code at home? you could download a c++ ide for linux (code:blocks isnt too bad) and write code on that and then copy it to windriver on a windows computer whenever you want to download it to the crio.
Unread 17-01-2010, 16:17
rkelly23 rkelly23 is offline
FRC #2975
rkelly23 will become famous soon enoughrkelly23 will become famous soon enough
NetBeans is a Java IDE only. Just download a C++ IDE
Unread 17-01-2010, 18:25
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
All of you are wrong... netbeans is an all rounder, from php to java to c/c++...
http://netbeans.org/features/cpp/index.html
Unread 17-01-2010, 22:12
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
No, you can't compile C++ code for the robot using NetBeans. Yes, you can write C++ code in NetBeans, and copy it into WindRiver Workbench. Personally, I would use Eclipse to write the C++ code at home, share it on a Subversion server, and do the rest of the work in WRW. WindRiver Workbench is based on Eclipse, so Eclipse will act and feel like WRW, which may make switching back and forth more comfortable.
Another option would be to download the WRW trial for Linux, and see if you can copy over the license files and FRC-specific stuff. I don't know how hard this would be, or if it's even legal. The WPILib guys would probably be interested if you got it to work, though.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
NetBeans not talking to the cRio scottbot95 Java 21 07-02-2010 14:19
Downloading code: Netbeans does not reset cRIO ellisk Java 8 31-01-2010 19:02
Deploying code from the 2010 driver station - Netbeans joshholat Control System 5 23-01-2010 15:01
Netbeans/Overall Java/Code help!!! a kenny03 Java 5 18-01-2010 22:32
Help with NetBeans frcchile Java 4 13-01-2010 21:51
