Re: Car Nack Predicts 2010-1
How about this?
3. At least one person will be injured with the trident during game-play. |
I'm worried you may be right. And with the non-ball end, no doubt. I hope everyone's human players have practice to feed balls up so they can do it slowly and calmly, without whipping that thing around.
On the topic of hanging, those that were around in 2004 remember how fast robots were able to climb the stairs and platforms and hang with just seconds left in a match. I remember robots that were able to hang and lift with seconds left in the matches on a consistent basis using very simple mechanisms. 8 points in the end game, I can see it happening, and I think the regional(s) that I will be able to attend I will see it with my own eyes.
Best of Luck |
I think we wont see it largely because the top team is unlikely to be comfortable supporting 450(ish)lbs from their tower grabber widget. If its beefy enough to hold up 450 lbs of robot, its going to be heavy, and i doubt anyone is going to make that design tradeoff.
EDIT: Unless, of course, the GDC decides to make it more worth our while... like say... a 2nd SUSPENDED ROBOT is worth a 2x or 3x multiplier to either the hanging stack, or the goals scored. |
I don't think it'll be seen because I don't know how much most teams can be trusted to try and attach themselves to someone else's robot without breaking something. The point values don't make it worth it, IMO. |
#7
-dave . |
#9
I have to agree with Car Nack, it will be tricky, but i believe if there was a robot out there that allowed a simultaneous climbing by two robots at once that would really relieve some of the pressure of staying on the field to score, as they could wait longer until they have to set up, because both other teams could climb at the same time.
#11
When you see the answer to this you will kick yourself for not thinking of it. It is really simple. The question we still have is, "Is it worth it?".
#13
What is the very simple solution to this problem? |
#14
I have ideas for it, even though my team wont attempt it and i dont believe they should attempt it, but with a little innovation, i think you could do it eazier than you think.
A robot that has bars on both.... |
#15
It can be done with drive-on platforms, barely. I'm sure that there is a much more clever solution.
| Car Nack Predicts #2-09 | Car Nack | Car Nack's Corner | 3 | 25-02-2009 10:24 |
| Car Nack Predicts #2-08 | Car Nack | Car Nack's Corner | 14 | 11-04-2008 10:32 |
| Car Nack Predicts 01/08/07 | Car Nack | Car Nack's Corner | 47 | 22-03-2007 10:07 |
| Car Nack Predicts 04/06 | Car Nack | Car Nack's Corner | 13 | 21-02-2006 13:24 |
| Car Nack Predicts | archiver | 2000 | 2 | 23-06-2002 21:59 |
