Go to Post Do not worry about the VEX camp versus FIRST camp issues. It is a huge marketplace. It is only about 4% penetrated. There is room for everyone. And competition is good for the consumer. - ebarker [more]
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 17-01-2010, 17:49
Nibbles Nibbles is offline
Interstellar Hitchhiker
AKA: Austin Wright
FRC #0498 (Cobra Commanders)
Nibbles is just really niceNibbles is just really niceNibbles is just really niceNibbles is just really niceNibbles is just really nice
Re: C and LabView version control with Git
There is a 3rd party diff implementation called LVDiff which uses the existing VIs provided with the Development system to perform a diff. It has a bit of overhead, all you really need is to run a supplied VI with the two files and LabView will launch the diff tool (I have a .vi that can do this correctly parsing the command line arguments, I'll attach it when I get the chance). In the "2009" edition of the documentation (but not 8.6) there is a pre-provided LVCompare.exe file that does the same thing, compiled into a binary. LVMerge.exe is the official merge tool and is provided with our 8.6 version, but it doesn't seem to be writing over the correct file, instead returning a successful result, but not writing it out, thus taking one file as the merged result entirely ignoring the other... the only explanation I can come up with is a software bug.
I have played around with TortoiseGit (forked from TortoiseSVN), you can get two changes in two separate files to merge into one? I can get as far as calling LVMerge with the (as I understand) correct arguments (or using the merge under Tools->Source Control iirc).
Help standardize match data! Use the XML interchange format. (Specification page)
AAA_awright on Freenode IRC chat. (Join us at ##FRC on chat.freenode.net, or in your browser)
  #32   Spotlight this post!
Unread 17-01-2010, 19:22
sparrowkc sparrowkc is offline
AKA: Mark
FRC #1986 (Team Titanium)
sparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to behold
Yes, after following the instructions in my previous post, merging seems to work.
For a test, I created a simple VI that uses a loop with a shift register to increment a number. I immediately created a new branch and switched to it. In that branch, I replaced the shift register with a feedback node. I committed and checked out the master branch. In the master branch, I added a time delay to make the counter run slower. I committed master. I then did a merge from the second branch into master and it worked just like in the tutorial. The resulting file has a feedback node and a time delay.
I've also tried making conflicting changes to the robot code. It made me choose which version of the conflict I wanted to keep, and honored my choice.
I really like this.
2009 Control System LabVIEW Tips and Pitfalls Travis Hoffman NI LabVIEW 3 22-12-2008 11:25
LabVIEW Training and new control system demonstration 10/17-10/19 in Frazier Park, CA Joe Ross NI LabVIEW 0 25-09-2008 13:25
First problems with FTC and Labview PhilBot National Instruments LabVIEW and Data Acquisition 0 10-09-2008 20:21
Labview and communication with peripheral device help jaijaidin LabView and Data Acquisition 3 26-01-2007 19:17
version control and linux shtylman Programming 2 01-05-2006 17:44
