Re: Drive Sizing 101
Neat stuff, Paul!
Some major gear reduction going on there... my best guess would be that you're simply rotating the robot up 90 degrees (or perhaps less) with your transmission directly driving whatever grabby-type arm you have planned. It takes about 3 seconds to raise a robot to the desired height at max power (with an FP), which fits somewhat closely with the reduction you chose. Of course, you guys won't be bothered trying to grab the top of the bar... I bet one vertical bar is sufficient. ![]() I'm wondering why you guys are using such a wimpy motor though... don't you have 4 CIMs sitting in your drivetrain that won't be doing anything during the lifting period? |
I started doing a little research on getting an FP 1500:1 and I may be missing something, but it looks like a gigantic task of gearing this without adding a ton of weight. I would love to see how you plan on accomplishing this, but I have a feeling you may be reluctant to give up your secret recipe
I encourage everyone to try and solve this instead of just guessing. (its more fun/rewarding that way)
I tried a few quick equations (by no means correct) and came up with my guesses. Highlight line below to see. Either a scissor jack (more likely) that grabs the top bar, or a 0.5 metre rotational arm that attaches to a vertical bar on the tower. Additional assumptions I made: The robot is lifted from Center of Gravity 5 seconds is just lift time (does not include time to raise mechanism) Wouldn't use a winch with a 0.4 metre radius ![]() |
Judging by the reduction, winch can be discounted from the possible ideas because you would get a ridiculously slow lift speed geared that low. That brings us to arm. At 1500:1 a FP motor can spin at about 60 deg/sec.
At 1/3 stall torque, a 14" arm supporting the weight of the robot would require approximately the reduction you described. Added to a lightweight apparatus raising the robot height to 60", this comes within grabbing distance of the bar. This would not bring the robot clear of the platform when raised, though. If, however, the robot is starting from the top of the bump, it could easily clear the platform when raised with only a 50" or so robot. This brings into question the raised center of gravity when navigating to the top of the bumps. With a scissor jack, the linear speed of the motor would be multiplied by the number of links in the jack. Added to the fact that a lead screw would make a very convenient way to achieve the large reduction you want. Since the scissor lift also can achieve a large gain in height with a small retracted space, as well as the large reduction and issues with the other two designs, this is my guess for #2. As for #1, I am unsure of the math behind lead screw reductions, so I will leave that for someone else. ;-) |
1.) FP has a Torque of 0.45 Nm, which is equal to 3.982 in*lbs.
3.982 in*lbs x 1,500(gear ratio) = 5,973 in*lbs Code:
5,973 in*lbs / 150 lbs (weight of Robot) = 39.82 inches Code:
15,600 RPM / 1,500 (gear ratio) = 10.4 RPM Code:
10.4 RPM / 60 seconds = 0.173 RPS Code:
0.173 RPS * 5 Seconds = 0.867 of a Revolution = 312 degrees That is my guess. -Clinton- |
#7
Here's my guess -
Assuming long, you've got 35 inches or so in your bot to stow an arm. I'm also assuming you need to stay under 17.5 to go under the platform, which means you can't really "slant" you arm from front to back to get increased length while stowed. This gives you a 3 foot horizontal bar. If you use that bar and hook it on the vertical tube, you can pull down on the end. With a tiny bit of clever engineering, you can "lock" the bar in place just using that torsional force, then spin your robot up and over it (inverting your robot) and placing it high enough to score - while only using the one motor to pivot the arm. So, if you put another 1/2 length arm, hinged from the center of the bot, and put the motor at the end of that connected to the longer 35 inch arm, you could release the shorter arm, say 16 inches long. It will pop up on the gas shock. This plus your 16 inch height robot height is more than enough to get it above the scoring height limit. Then you simply click your horizontal arm into place against the vertical bar and invert your robot. Tell me you're going to invert your robot. I'm drooling to see it ![]() PS: This fits reasonably well. At 10 RPM roughly, you rotate 1 time every 6 seconds. 16 inches, the length of the shorter arm that rises from the center of your robot is about right for the torsional arm you'll be working with. It packages within the long driver base with an inch or two to spare too. Last edited by Tom Line : 18-01-2010 at 01:43. |
#8
I agree with Tom's guess...
When do we hear the answer? |
#9
We looked at doing that exact thing, but the torsional force on the tower scared us away - over half a ton that your end effector would have to hold. I'm sure it's doable, but we didn't want to deal with the high forces.
#10
O.K. here are some of the answers:
1. We are NOT going in the tunnel. 1/2" of clearance on either side is just not enough for us and making our robot skinnier is just not something we are willing to do. 2. We are using a single rotational joint to do our lift. 3. We are inverting ourselves Calculations: We make sure our design point is at Max Power. As the torque goes down the speed picks up and we have plenty of torque at start-up. F-P speed at max power = 7800 RPM F-P torque at max power = .1648 ft-lb CG location from pivot = 18" Robot Weight = 150 lbs Required Torque = 225 ft-lbs (150 lbs * 1.5 ft) F-P Torque at 1500:1 at max power = 223.45 ft-lbs F-P Speed at 1500:1 at max power = 31 deg / sec Rotation angle = 90 degrees so total time is ~3 seconds. Now at various points along the rotation the speed will change based on the CG moving closer to the pivot. We can also always add Latex tubing if our CG is further out than we think. |
#11
For those looking for the extra credit, what Efficiency did 217 use in their calculations?
#12
Nice. I would challenge someone to now tell us how much torque will be on the vertical tower post in worst case, and how thick the end effector will need to be to handle that torque....
#13
I am going to say somewhere in the 60%-70% range, but it could also be as low as 50%. The reason I would guess 50% is it is half of the full power, so if it could do it in the set constraints at 50%, then at 100% or anything greater than 50%, it would be guaranteed every time.
#14
Tom,
The force on the latch is much lower than you think. The design we are using is made such that the contact forces on the vertical pole are greatly reduced. Paul |
#15
I'm very anxious to see your comp bot then. With our initial design, when the bot was out at the end of the 36 inch arm plus the 18 inch riser, we had 54 inches (call it 4.5 feet). With the 150 pound robot at the end, that's 675 foot-lbs. However, our initial end effector was only 6 inches tall, so the torsion on the top point was 675 ft-lbs / .5 ft = 1350 lbs. Of course, we were trying to package within a 16 inch tall robot, which is why we limited it to 6 inches tall.
Since you're not worried about the tunnel, I suspect you didn't have that constraint regarding packaging. |
| Fundraising 101 | SpaceOsc | Fundraising | 8 | 17-01-2013 19:47 |
| Robot Sizing Question | i like dirt | Rules/Strategy | 3 | 08-01-2007 22:23 |
| Has anyone seen the FVC sizing box? | Richard Wallace | FIRST Tech Challenge | 6 | 13-05-2006 20:14 |
| pic: FVC Sizing Box | Richard Wallace | Extra Discussion | 5 | 07-12-2005 18:58 |
| Down Sizing pictures to upload | BobC | General Forum | 7 | 24-02-2005 12:51 |
