Go to Post I'd just give you the URL, but then you wouldn't learn to look for yourself. - DonRotolo [more]
Unread 17-01-2010, 15:59
team2491 team2491 is offline
FRC #2491
team2491 is an unknown quantity at this point
Rules for Pneumatic Tires?
Hey,
our team has been determining our ideal wheels, and given our searches, we've found some pneumatic tires that seem to fit our needs perfectly.
I havent found any specific rules against them, but I figured that, after searching chief delphi to no avail, I should at least check to see if there are any obscure rules that would prevent us from using them. Or alternatively, any huge design oversights we may be missing.
Thanks in advance,
Team 2491
Unread 17-01-2010, 16:17
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Re: Rules for Pneumatic Tires?
there are no rules prohibiting the use of pnuematic (inflatable) wheels.
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 17-01-2010, 18:21
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
If you are making a long wheelbase 4 wheel drive, pneumatic tires can really magnify the turning problems that design can have.
2016 Central Illinois Winner. Curie Division finalist
Unread 17-01-2010, 18:30
This rule seems to cover your question. Please note that the tread design may have an effect on carpet damage so choose wisely. It might be wise to ask the Q&A to be sure.
R08> ROBOT wheels, tracks, and other parts intended to provide traction on the FIELD may be purchased or fabricated (“traction devices” include all parts of the ROBOT that are designed to transmit any propulsive and/or braking forces between the ROBOT and the FIELD). In no case will traction devices that damage the carpet or other playing surfaces be permitted. Traction devices shall not have surface features such as metal, sandpaper, hard plastic studs, cleats, or other attachments. Anchors (i.e. devices that are deployed/used to keep one’s ROBOT in one place and prevent if from being moved by another ROBOT) shall not use metal in contact with the carpet to “stay put.” Gaining traction by using adhesives or Velcro-like fastener material is not allowed.
Unread 17-01-2010, 18:50
GaryVoshol's Avatar
Cogito ergo arbitro
Does this Q&A effectively ban pneumatic tires? http://forums.usfirst.org/showthread.php?t=13703
Originally Posted by Q&A
If the item were inflated by the pneumatic system on the ROBOT, then it would be considered a pneumatic part. As such, it would be prohibited by Rule <R71>. Note that no source of compressed air other than the provided compressor (or equivalent, as permitted by Rule <R75>) is permitted. Thus, an additional inflatable item that is actually inflated would be prohibited. However, an inflatable item that not connected to a pneumatic system and is used in its deflated state would be permitted (assuming it didn't violate any other rules).
(since 2004)
Unread 17-01-2010, 19:33
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Wow, that Q&A does seem to ban anything that is inflated (I think I am interpreting it like you are).
Just a little note, make sure your autonomous is smart enough not to crash into walls and keep going. In overdrive a team at our competition had big 8 or 10" pneumatic tires and their autonomous went full speed ahead into the far wall and kept driving after impact damaging the carpet.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 17-01-2010, 20:08
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
I was thinking the same thing... i don't know if they were not thinking about pneumatic tires when they posted this OR if they are worried robots might pop a tire launching over a bump.
Unread 18-01-2010, 08:09
Gary,
I think it just muddies the waters. Since the inflated tire is not being used as stored energy on the robot, nor is it connected to the pneumatic system, I can't see how it would be considered to be a non-legal pneumatic part. I do not speak for the GDC however and this question needs to be put to the Q&A directly as it is. I can tell you that robots have had inflatable tires in many of the past seasons. In many games where climbing was part of the game, teams have used bicycle tires to help assist in the climbing action. I do not remember that inflatable tires have been specifically disallowed in the past.
Perhaps a member of the GDC could comment here for some guidance.
Unread 18-01-2010, 11:51
Racer26 Racer26 is offline
I know that 1075 in 2004 used 14" bicycle wheels to climb the stairs. I can't say for sure that the GDC is or isnt banning them this year, but I suspect that they had just overlooked pneumatic tires when discussing inflatables.
Unread 18-01-2010, 15:55
The simple answer is to inflate your pneumatic tires with the KOP compressor.
Unread 18-01-2010, 16:06
Chris is me's Avatar
AKA: Pinecone
Then <R71> prohibits it.
Unread 19-01-2010, 17:28
James Dowd's Avatar
James Dowd James Dowd is offline
A Michigan Man
FRC #1739 (Chicago Knights)
James Dowd will become famous soon enoughJames Dowd will become famous soon enough
Send a message via AIM to James Dowd
From Team Update #3:
J. For the purposes of the FIRST competition, air-filled (pneumatic) wheels are not considered pneumatic devices, and are not subject to the pneumatic rules (although they must still satisfy all other appropriate rules).
For Reference:
Team Update #3
James Dowd
FRC Team 1739 Mentor, FTC Team 329 Coach
Former Team 830 Mentor and Coach
Former Member of Team 573
2009 Wisconsin Regional Engineering Inspiration Award, Midwest Regional Engineering Inspiration Award
2007 Waterloo Regional Xerox Creativity Award
2006 Waterloo Regional Autodesk Visualization Award
2003 West Michigan Regional Engineering Inspiration Award, Buckeye Regional Xerox Creativity Award
2001 Curie Division Finalist, Great Lakes Regional Finalist, West Michigan Regional Rookie All-Star Award
Unread 23-01-2010, 11:15
FRC #2491
thank you for all your responses, but our team has found some nice non-pneumatic wheels that suit our purposes just fine.
Again I would like to thank you all for your clarification though!
Rules of Pneumatic system frcchile Rules/Strategy 2 16-01-2010 14:19
pneumatic rules ? mcktim Rules/Strategy 2 29-01-2006 13:59
relaxing of pneumatic rules and IFI Joe Ross General Forum 3 23-02-2004 00:02
Wheel wear??? 6" Pneumatic tires??? Scott358 Technical Discussion 11 29-03-2003 13:35
Tread for tires! geo Technical Discussion 2 04-02-2002 18:31
