Go to Post [This year's game manual contains] 46 new pages of pictures displaying how to attach bumpers, assuring at least 15% of teams almost get it right this time. - PayneTrain [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 17-01-2010, 20:13
ubermeister's Avatar
ubermeister ubermeister is offline
AKA: Eric VA
ubermeister is a jewel in the roughubermeister is a jewel in the roughubermeister is a jewel in the roughubermeister is a jewel in the rough
Where to buy vacuum impellers
Our team is looking for a vacuum impeller to use on our robot. We want to get an effect similar to a shop vac, but do not want to purchase an entire shop vac just to get the impeller. The shop vac one is appealing since it is thin, metal, fairly small, and enclosed on both sides except for the vacuum hole. However, any reasonably powerful impeller will do. Any thoughts as to where to purchase one?
Unread 17-01-2010, 20:44
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Re: Where to buy vacuum impellers
MSC has impellers listed here;
http://www1.mscdirect.com/CGI/GSDRVS...ILSEQ=13&SIOR=
But they seem a little pricey, more than a shopvac...And Grainger has them listed here for a much better price;
http://www.grainger.com/Grainger/hva...search&sst=All
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 19-01-2010, 22:51
AKA: Eric VA
In case anybody else is wondering, I found a very nice impeller inside of this vacuum:
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
It is only a $20 vacuum, so I have no qualms about tearing it apart just for the impeller. The impeller is the kind normally found in larger shop vacs. It is made of sheet steel, and is 5" in diameter and about .3" thick. It is enclosed on both sides. The intake hole is a bit under 2" diameter, and it has a 5/16" hole for mounting to a shaft. The impeller easily comes off by clamping the motor still with vice-grips and unscrewing the nut that holds it on.
We haven't tried attaching it to a kit motor yet (need to turn an adapter), but so far, I highly recommend this impeller.
Where to buy Buy FRP in AZ? falconmaster General Forum 9 05-01-2009 16:36
Where to buy x???? FIRST JerseyKid Technical Discussion 10 23-05-2007 23:52
Where to buy sprockets sdcantrell56 Technical Discussion 3 19-01-2006 18:44
where to buy treads? illumanat'i Technical Discussion 11 11-01-2004 22:05
where to buy! Ben Mitchell General Forum 2 20-01-2002 23:14
