| Thread Tools |
Rating:
Display Modes |
Holonomic drive vi with mecanum wheels
Does anyone know if the Labview Holonomic drive VI works with the mecanum wheels?
Re: Holonomic drive vi with mecanum wheels
As I understand it, the control of mecanum drive is different than holonomic. Check out this paper for the math behind both drive systems.
http://www.chiefdelphi.com/media/papers/1836 Barry |
Yes... the ambiguously named holonomic drive VI is designed for use with mecanum wheels, not omni wheels. Sorry for the confusion. Also note that there is a bug in the documentation for the Rotation input terminal... The detailed help says that the units for this input is in degrees per second. This is incorrect. The input has the range -1.0 to 1.0. 1.0 means spinning clockwise at full speed and -1.0 is counterclockwise.
Holonomic is a class of motion capability. Mecanum wheels are a specific design that can achieve holonomic motion. In other words, mecanum drive is one type of holonomic drive.
In my experience, the programming for both mecanum and omniwheel systems is the same.
If your omni-wheeled robot is using 3 wheels at 120 degrees, your drive system is still holonomic, but this VI can't help you. Also, swerve drive systems are holonomic but could not be controlled by this VI. That's why I don't care for the naming of it. Last edited by jhersh : 18-01-2010 at 00:42. Reason: spelling ;) |
#7
If you are using mecanum wheels, the rollers are at 45 degrees to the wheel axle, and should therefore be mounted inline on each side (just like you would do for tank drive with 4 independent motors using regular wheels). |
| How do you wire the inputs for holonomic drive (omni wheels) | star_lancer | NI LabVIEW | 8 | 22-01-2010 22:29 |
| Forklift project with mecanum wheels HELP | adra | Technical Discussion | 12 | 21-01-2009 00:44 |
| Help with mecanum wheels | CyDrive | Programming | 7 | 10-02-2008 16:16 |
| Assistance with Mecanum Wheels | CollmandosGrl | General Forum | 8 | 14-01-2008 17:42 |
| Teams With Mecanum Wheels | Foss@Team176 | Technical Discussion | 15 | 06-10-2005 09:38 |
