Go to Post By far, the worst thing about it was the severe lack of cowbell. There was no cowbell what so ever. Had there been cowbell that would have completely changed everything for me. - Wildcat [more]
Unread 17-01-2010, 13:30
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
pic: Articulated 6WD prototype
Unread 17-01-2010, 13:31
AKA: Ty
Re: pic: Articulated 6WD prototype
How did this end up upside-down?
Edit: Thank you
Unread 17-01-2010, 14:03
J_Beth J_Beth is offline
AKA: Justin Beth
FRC #0935 (RaileRobotics)
J_Beth will become famous soon enoughJ_Beth will become famous soon enough
That looks cool. Where did you guys find this idea, or did you design it yourselves? I was trying to figure out a way to do something similar.
Unread 17-01-2010, 14:07
GaryVoshol's Avatar
Cogito ergo arbitro
I can't tell for sure, but as the center wheel goes up, do the outside wheels go down? If so, wouldn't that make the BUMPER ZONE move?
(since 2004)
Unread 17-01-2010, 14:32
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Well that brings up another question. How is the bumper zone height defined while on the bump?
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 17-01-2010, 15:33
professor1212's Avatar
professor1212 professor1212 is offline
NASA Space Grant Intern
AKA: Moheeb Zara
FRC #1212 (The Setinels AKA Holy Hamsters)
professor1212 will become famous soon enoughprofessor1212 will become famous soon enough
we found that just raising the chassis with a regular 4 wheel drive works just fine. Also the bumper rules are a bit different this year, I don't remember the exact height, but it is drastically larger than the 2inch restriction from previous years.
So although I personally love the 6 wheel drive configuration, it just seems more practical to save weight and work with 4 wheels.
But don't let that stop you from trying it!
Me: Why are you drilling your shoes?
Abdul: To make them lighter.
"Testtubes and Tesla coils,
clockwork brain 'n' glowing oils,
copper, brass, explosive jelly,
his mechapede policed Old Delhi.
Invented the radio transmitting, too.
Played poker with Theremin, Tesla and Poe.
Harnessed cold moonlight to power airships
and destilled antitoxines from postnasal drips. "
Unread 17-01-2010, 15:40
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Driving over the bump looks easiest with a robot that has an open area in the middle of the drive train (as viewed from the side). That implies that 4wd or 8wd might be the way to go. 6wd seems to add a lot of complication to try to overcome the falling problem as the robot crests the bump.
And if your center wheels can lift up to follow the bump, the can probably also lift up in normal driving? so you really have a long wheelbase 4wd robot anyways.
Unread 17-01-2010, 16:35
GaryVoshol's Avatar
Cogito ergo arbitro
Originally Posted by <R07>
A. BUMPERS must provide complete protection of the entire FRAME PERIMETER of the ROBOT (i.e. BUMPERS must wrap entirely around the ROBOT). The BUMPERS must be located entirely within the BUMPER ZONE when the ROBOT is standing normally on a flat floor, and must remain there (i.e. the BUMPERS must not be articulated or designed to move outside of the BUMPER ZONE).
My interpretation of this is that the BUMPER ZONE moves as the robot moves. It has to be this way, else an ELEVATED robot would move the BUMPERS out of the BUMPER ZONE. So if the robot is tipped or elevated as it goes over the bump, the BUMPER ZONE tips or elevates correspondingly. That means if the articulated wheelbase lowers the wheels, the BUMPER ZONE is measured from those lowered points. Before proceeding with an articulated design, it should be verified with Q&A.
(since 2004)
Unread 17-01-2010, 18:00
AKA: Ty
Thanks, i had thought of this for an all terrain Modular UGV that my buddy and i are making. we were intending to use our oun design of tension/compression nitrogen shocks, but this is how it has to be done with the legos i have available. it still demonstrates the concept the same regardless.
Unread 17-01-2010, 18:22
trilogy2826's Avatar
trilogy2826 trilogy2826 is offline
Mentor - 2826
AKA: Jake Fischer
FRC #2826 (Wave Robotics)
trilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond repute
I put in several questions to the Q&A last Thursday, including this one. This is one of two I have yet seen a reply posted against from the GDC.
Unread 17-01-2010, 21:38
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
<r07> The BUMPERS must be located entirely within the BUMPER ZONE when the ROBOT is standing normally on a flat floor,
If you read the last four words in this part of the rule the measurment is when the robot is on a flat floor. This most likely will be done durring inspection on a flat floor. All the robots bumpers will change there hieght durring transition through the bump, thier is no way around it. It also say's you can not articulate the bumpers from the frame but it dose not say anything about articulating the drive wheels.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 19-01-2010, 12:28
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
I like it! I wish our team had decided to do 6 wheel drive... instead we are using a swerve drive which looks promising but very time consuming to build and program.
Unread 19-01-2010, 12:31
Dancin103 Dancin103 is offline
The Crazy Blonde
AKA: Cassie
FRC #0103 (Cybersonics)
Dancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond repute
Send a message via AIM to Dancin103
Originally Posted by Tytus Gerrish View Post
It's a great idea and is very creative.
Cass
Cybersonics Technology Team 103
2003 Championship Chairman's Award Winners
NEED CHAIRMAN'S HELP?? Subscribe to our YouTube Channel, we answer your questions daily!
Unread 19-01-2010, 14:42
Pat Major's Avatar
Pat Major Pat Major is offline
#0494 (The Martians)
Pat Major has a reputation beyond reputePat Major has a reputation beyond reputePat Major has a reputation beyond reputePat Major has a reputation beyond reputePat Major has a reputation beyond reputePat Major has a reputation beyond reputePat Major has a reputation beyond reputePat Major has a reputation beyond reputePat Major has a reputation beyond reputePat Major has a reputation beyond reputePat Major has a reputation beyond repute
Joe how about a link to a video of your 6 wheeled articulated frame robot that you are currently driving around? I think others would enjoy it.
A river is powerful because many drops of water have learned the secret of collaboration.
Unread 19-01-2010, 18:02
joeweber's Avatar
Coach team 1322
Video of our test robot with six wheel drive suspension going up a ramp.
http://www.youtube.com/watch?v=xby0S...layer_embedded
Video of our test robot going up a 45 degree ramp.
http://www.youtube.com/watch?v=jQMcw4QNCLI
Link to our web site with pictures of our development.
http://www.team1322.org/ideas.htm
pic: Prototype 6WD kajeevan Extra Discussion 26 06-07-2009 03:18
pic: FRC1293 Prototype 6wd Chassis Thermal Extra Discussion 16 06-01-2009 23:12
pic: 6wd prototype chassis Collin Buchan Extra Discussion 7 03-01-2009 10:00
pic: 6wd prototype chassis Collin Buchan Extra Discussion 3 02-01-2009 14:14
pic: GUS Team 228's 6WD Sheet Metal Prototype Chassis artdutra04 Extra Discussion 14 02-01-2009 02:11
