Go to Post Truly good teasers should give people a good place to start guessing, while still leaving some mystery and uncertainty. - Travis Covington [more]
Unread 17-01-2010, 21:50
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: using CAN with the 2010 control system
BTW, the plugin for the 2CAN has not been released yet. When it is, you will be able to find it at FIRST Forge.
Another way to connect to CAN is to use the new Black Jaguar as a serial to CAN bridge. You just make the cable according the the getting started guide from TI and plug it straight into the RS232 serial port on the cRIO. This way you don't need to buy a separate bridge device and can simply use one of your motor controllers. The driver plugin for using the Black Jaguar as a Serial to CAN bridge is posted on FIRST Forge.
If you are going to use a lot of motors in open loop mode, you may need the additional bandwidth of Ethernet.
Tips for C++ programming the 2010 control system woodk C/C++ 12 23-01-2010 21:38
2010 Control System Manual screamingeagle FRC Control System 9 11-01-2010 14:01
Unclaassified: Information about the 2010 control system Nadav Zingerman General Forum 35 24-11-2009 19:17
Do we have to ship the control system along with the robot on Tuesday? tennisbeast29 Rules/Strategy 3 14-02-2009 13:39
