Go to Post Come on guys, its not like it's rocket surgery or anything. - hallk [more]
Unread 17-01-2010, 21:55
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Encoder problems
Originally Posted by Pausert View Post
Today I was working on the KOP optical encoders and under no circumstances could I get them to work. I placed the Open encoder and the Set encoder function outside the teleop loop and the Get encoder function in the execute case. This setup worked for my other sensors and I know the encoder works. What am I missing? See code attached.
You should under no circumstances create create constants for "DevRef" inputs. You need to open the digital inputs and pass those references into the "ToDigitalSource.vi" (on the encoder pallete) and pass the reference from that into the encoder open. Look at the Encoder Example for... well... an example.
Unread 18-01-2010, 12:33
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
Have you tried the Encoder Example? In LabVIEW choose View>>Getting Started Window, then click Examples and pick Encoder Example from the list. It also shows the wiring, so you can make sure that matches as well.
Problems with Encoder Counting bjimster1 Programming 19 07-03-2007 09:59
Encoder Counting Problems RyanW Programming 1 14-02-2007 15:17
Encoder Problems bjimster1 Programming 2 10-02-2007 08:04
Encoder Output Problems Mike Electrical 5 25-11-2005 21:43
