Go to Post Is that severed hand legal? I think it's a COTS assembly from previous years. - Taylor [more]
Unread 16-01-2010, 17:40
Pausert Pausert is offline
FRC #1727 (REX)
Pausert is an unknown quantity at this point
Encoder problems
Today I was working on the KOP optical encoders and under no circumstances could I get them to work. I placed the Open encoder and the Set encoder function outside the teleop loop and the Get encoder function in the execute case. This setup worked for my other sensors and I know the encoder works. What am I missing? See code attached.
Unread 16-01-2010, 21:11
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Re: Encoder problems
You should put the initialize parts of the sensor code in the init loop. Also I would try putting the configtimerm.vi before the start.vi. also try looking at the error statements to see what that gets you.
Unread 17-01-2010, 21:55
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
You should under no circumstances create create constants for "DevRef" inputs. You need to open the digital inputs and pass those references into the "ToDigitalSource.vi" (on the encoder pallete) and pass the reference from that into the encoder open. Look at the Encoder Example for... well... an example.
Unread 18-01-2010, 12:33
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
Have you tried the Encoder Example? In LabVIEW choose View>>Getting Started Window, then click Examples and pick Encoder Example from the list. It also shows the wiring, so you can make sure that matches as well.
Problems with Encoder Counting bjimster1 Programming 19 07-03-2007 09:59
Encoder Counting Problems RyanW Programming 1 14-02-2007 15:17
Encoder Problems bjimster1 Programming 2 10-02-2007 08:04
Encoder Output Problems Mike Electrical 5 25-11-2005 21:43
