Go to Post Just wait till Heidi learns video-editing skills. - tkwetzel [more]
Unread 14-01-2010, 09:50
dwodrich dwodrich is offline
FRC #1706
dwodrich has a spectacular aura aboutdwodrich has a spectacular aura aboutdwodrich has a spectacular aura about
Holonomic drive vi with mecanum wheels
Does anyone know if the Labview Holonomic drive VI works with the mecanum wheels?
Unread 16-01-2010, 00:53
Green2 Green2 is offline
FRC #2338
Green2 is an unknown quantity at this point
Re: Holonomic drive vi with mecanum wheels
As I understand it, the control of mecanum drive is different than holonomic. Check out this paper for the math behind both drive systems.
http://www.chiefdelphi.com/media/papers/1836
Barry
Unread 17-01-2010, 20:50
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Yes... the ambiguously named holonomic drive VI is designed for use with mecanum wheels, not omni wheels. Sorry for the confusion. Also note that there is a bug in the documentation for the Rotation input terminal... The detailed help says that the units for this input is in degrees per second. This is incorrect. The input has the range -1.0 to 1.0. 1.0 means spinning clockwise at full speed and -1.0 is counterclockwise.
Unread 17-01-2010, 20:54
Holonomic is a class of motion capability. Mecanum wheels are a specific design that can achieve holonomic motion. In other words, mecanum drive is one type of holonomic drive.
Unread 17-01-2010, 22:37
In my experience, the programming for both mecanum and omniwheel systems is the same.
Unread 18-01-2010, 00:13
True... but it does assume that you have mounted your omni wheels at 45 degrees in the corners of your robot for the direction parameter to have the same meaning. Given that this is usually more difficult than mounting them along the 4 sides, it seems less likey that the VI as supplied will apply directly to a typical omni wheel design.
If your omni-wheeled robot is using 3 wheels at 120 degrees, your drive system is still holonomic, but this VI can't help you. Also, swerve drive systems are holonomic but could not be controlled by this VI. That's why I don't care for the naming of it.
Unread 18-01-2010, 13:44
star_lancer's Avatar
star_lancer star_lancer is offline
Programming Addict
AKA: Mike Berney
FRC #2346 (CRASH)
star_lancer is a jewel in the roughstar_lancer is a jewel in the roughstar_lancer is a jewel in the rough
Send a message via AIM to star_lancer Send a message via Yahoo to star_lancer
So do you need to have your mecanum wheels mounted on the corners at 45 degrees for the holonomic VI to work? I'm just a little confused.
If you found anything I said helpful, please click the scales next to my post. I really appreciate those reputation points.
Team 2346 - Build, test, panic, repeat.
Unread 18-01-2010, 16:01
No... if you are using OMNI wheels (with the rollers at 90 degrees to the wheel axle) then you need them at 45 degrees in the corners.
If you are using mecanum wheels, the rollers are at 45 degrees to the wheel axle, and should therefore be mounted inline on each side (just like you would do for tank drive with 4 independent motors using regular wheels).
How do you wire the inputs for holonomic drive (omni wheels) star_lancer NI LabVIEW 8 22-01-2010 22:29
Forklift project with mecanum wheels HELP adra Technical Discussion 12 21-01-2009 00:44
Help with mecanum wheels CyDrive Programming 7 10-02-2008 16:16
Assistance with Mecanum Wheels CollmandosGrl General Forum 8 14-01-2008 17:42
Teams With Mecanum Wheels Foss@Team176 Technical Discussion 15 06-10-2005 09:38
