Go to Post Has anyone else figured out a way to slip robotics into any conversation possible? Salespeople, nurse, dentist, pizza delivery guy... they all hear about it... It's gotten to the point where telemarketers will no longer call me, I have to call them... poor telemarketers... - MissInformation [more]
Unread 17-01-2010, 23:37
PortugazD.Ace's Avatar
PortugazD.Ace PortugazD.Ace is offline
AKA: Timothy Gonzales
FRC #1165 (Team Paradise)
Team Role: Student
PortugazD.Ace is an unknown quantity at this point
Programming the PSoC
Does anyone have any idea how to program the PSoC from the kit of parts. Or how to use it? If anyone has any information on the matter, please post.
Unread 17-01-2010, 23:45
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Programming the PSoC
You can use it in one of two ways (or both I guess if you buy another one)...
It can be used on the classmate Driver Station to provide access to custom I/O such as buttons, knobs, LEDs, etc on your driver console. You must use the official provided firmware if you wish to use it this way.
It can also be used on the robot in any custom way you choose (i.e. a sensor interface for any special sensors you decide to use). You must make your own design and firmware for it in this use case. The easiest way to interface it with the cRIO is probably with I2C, though there are many other ways that are possible.
Unread 17-01-2010, 23:47
Team Role: Student
custom firmware???? Umm, can you put that in plain english?
Unread 18-01-2010, 00:03
The PSoC board has a processor and some reconfigurable mixed-signal logic fabric on board. Basically, you would need to write your own code to run on the board if you use it on the robot.
The expected use case for 99% of teams is that it will be used with the driver station to wire up buttons.
Unread 18-01-2010, 08:14
Geek 2.0 Geek 2.0 is offline
FRC #0107
Geek 2.0 will become famous soon enough
Are we allowed to write our own code for it? I was under the impression that we had firmware given to use by FIRST that we had to use. Didn't see anything in the rules about it.
Unread 18-01-2010, 10:01
See <R60N>
Unread 18-01-2010, 12:32
FRC #0107
Originally Posted by Joe Ross View Post
See <R60N>
...How can the FirstTouch NOT be used as a part of the Operator Console?
Unread 18-01-2010, 12:39
It can be used on the robot as a piece of custom electronics. In that case, you are allowed to reprogram it as you see fit.
Unread 18-01-2010, 16:26
Didn't I say all this yesterday? ...in the second post?
Unread 21-01-2010, 18:46
Team Role: Student
BTW, how would I connect it via I2C?
Unread 21-01-2010, 23:59
If using it on the robot, you just pick two of the pins, map them to an I2C peripheral in the PSoC and then wire it up to a digital sidecar.
Unread 23-01-2010, 10:30
Team Role: Student
Wha????
Unread 23-01-2010, 20:33
If you didn't understand any of that, you probably shouldn't try anything so advanced just yet. You can work on programming the board in the off-season if you like.
Unread 30-01-2010, 20:39
Team Role: Student
Thanks for the encouragement. |(
Unread 30-01-2010, 22:24
Jason Law's Avatar
Jason Law Jason Law is offline
Team Captain
FRC #2834 (Bionic Barons)
Jason Law is just really niceJason Law is just really niceJason Law is just really niceJason Law is just really niceJason Law is just really nice
Hi -
From the past few posts, I am under the impression that I do not need to connect or do anything with the PSoC board if we choose not to use it for any of the above things. Is that correct? In other words, I am asking if it is required to be used and connected to the Classmate PC. I read the control system documentation and did not see anywhere that it said that I needed it. Please tell me if my interpretation of these things are correct.
Thanks.
PSOC Interface Card Lafleur Technical Discussion 4 09-02-2010 13:26
Programming the IR Pi Boy Sensors 3 21-01-2008 15:47
Programming the vex microcontroller to respond to commands on the serial port crashoverride02 Programming 1 20-10-2006 14:17
Programming The CMUcam for the Vex controller 987HighRoller Programming 3 24-06-2006 15:27
Programming the IR James Hine Programming 1 10-03-2004 14:08
