Re: Programming the PSoC
The PSoC board has a processor and some reconfigurable mixed-signal logic fabric on board. Basically, you would need to write your own code to run on the board if you use it on the robot.
The expected use case for 99% of teams is that it will be used with the driver station to wire up buttons. |
| PSOC Interface Card | Lafleur | Technical Discussion | 4 | 09-02-2010 13:26 |
| Programming the IR | Pi Boy | Sensors | 3 | 21-01-2008 15:47 |
| Programming the vex microcontroller to respond to commands on the serial port | crashoverride02 | Programming | 1 | 20-10-2006 14:17 |
| Programming The CMUcam for the Vex controller | 987HighRoller | Programming | 3 | 24-06-2006 15:27 |
| Programming the IR | James Hine | Programming | 1 | 10-03-2004 14:08 |
