Go to Post My suggestion is to first focus in on your drive base. Get it running, and drive it into the ground and see what breaks. Then fix it. Rinse wash and repeat. - Andy A. [more]
Unread 18-01-2010, 00:13
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Holonomic drive vi with mecanum wheels
Originally Posted by Alan Anderson View Post
In my experience, the programming for both mecanum and omniwheel systems is the same.
True... but it does assume that you have mounted your omni wheels at 45 degrees in the corners of your robot for the direction parameter to have the same meaning. Given that this is usually more difficult than mounting them along the 4 sides, it seems less likey that the VI as supplied will apply directly to a typical omni wheel design.
If your omni-wheeled robot is using 3 wheels at 120 degrees, your drive system is still holonomic, but this VI can't help you. Also, swerve drive systems are holonomic but could not be controlled by this VI. That's why I don't care for the naming of it.
How do you wire the inputs for holonomic drive (omni wheels) star_lancer NI LabVIEW 8 22-01-2010 22:29
Forklift project with mecanum wheels HELP adra Technical Discussion 12 21-01-2009 00:44
Help with mecanum wheels CyDrive Programming 7 10-02-2008 16:16
Assistance with Mecanum Wheels CollmandosGrl General Forum 8 14-01-2008 17:42
Teams With Mecanum Wheels Foss@Team176 Technical Discussion 15 06-10-2005 09:38
