Go to Post "Nuclear" is pronounced "nu kli Er." It is NOT pronounced "nu kU ler." When you use this pronunciation, no matter how smart you may actually be, you sound like an illiterate dolt (are you listening, Mr. Bush?). - dlavery [more]
Unread 17-01-2010, 23:40
Spirator Spirator is offline
AKA: Munaum Muhammad
Spirator is a jewel in the roughSpirator is a jewel in the roughSpirator is a jewel in the rough
Fisher Price Motors
With the Fisher Price Gearbox, how would you attach it to a drum, any kind of drum as we we looking at a belt, but would that be stable enough? We'd like to see what the others are doing,
3132.
Unread 18-01-2010, 00:15
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: Fisher Price Motors
If you have access to a milling machine, the easiest way to attach to the output hub of the FP KoP gearbox is to mill an octagon-shaped aluminum plug that fits between the plastic flanges. Then just wrap a hose clamp around it, and you're done. You can either broach the aluminum plug for a live axle, or drill a hole pattern into it for dead axle applications (such as if this octagon shaped aluminum plug was bolted directly to your drum).
Here's a photo from the construction of our 2008 robot, which used this octagon aluminum plug. You can click through to the full resolution photo to see it in better detail.
Art Dutra IV
世上无难事,只怕有心人.
Unread 18-01-2010, 00:19
I can't believe I didn't think of that before. I'll ask our lead mentor if he has acess to a milling machine and we'll proceed from there.
Unread 18-01-2010, 00:35
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
3132.
Have you considered a DOUBLE DOOZY
We attached a Spool to the FP gearbox in 2008,
http://2008.discobots.org/node/33
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 18-01-2010, 00:53
silv940's Avatar
silv940 silv940 is offline
AKA: Sam Wilkins
FRC #1572 (Hammer Heads)
silv940 is an unknown quantity at this point
Send a message via AIM to silv940 Send a message via Yahoo to silv940
I would recommend using a couple machine screws that go through the plastic into tapped holes on the octagon aluminum hub. Then wrap a hose clamp to make sure its secure. . The hose clamps slipped on one of our robots.
Unread 18-01-2010, 14:25
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
If you can't find a mill, mark the aluminum plate carefully with the octogon and cut it out with a band saw. Leave it slightly oversize and clean up the sides with a file. It does not have to be all that precise to work.
You might also be able to get the part that mates to the white "crown" from a place that sells FP parts. The part is called a "jeep driver" and is pretty inexpensive. The jeep driver makes a pretty good drum by itself and, at least with some year's motors, was just about exactly the right size to make a drum for a robot lifting winch. The jeep driver used to be in the KOP so you might find a picture if you look though the old docs.
Christopher H Husmann, PE
"Who is John Galt?"
Fisher-Price Motors popo308 Motors 11 03-08-2007 22:05
Fisher Price Motors for Drill Motors archiver 2001 0 24-06-2002 00:22
Fisher Price Motors... archiver 2001 2 23-06-2002 22:36
4 fisher price motors? Jordan A. General Forum 2 12-01-2002 11:52
