Go to Post ...isn't that part of the point? For high schoolers to do things they "could not have" by themselves? - AdamHeard [more]
Unread 17-01-2010, 17:55
DumbDude1994 DumbDude1994 is offline
Its amazing, really.
FRC #0379 (RoboCats)
DumbDude1994 is an unknown quantity at this point
completely confused (classmate isue)
Whenever we try to run the Basic FRC cRIO Robot Project (no edits to code) and then move the joysticks nothing happens. And in the drivers station program the three lights are green (Stop button, Robot Code, and the other one that slips me at the moment). In the errors section it says something about lack of communication with the camera.
Setup
Test board wired to specs from here under Hardware Documentation
with one sidecar and no signal light. Then off of the classmate is the 4 port hub (red and black usb in) and an ethernet cable going to the cRio (note no I/O). On the classmate Labview update and drivers station update applied (from above link, under software section) with nicyapi.dll added to windows/system 32.
Any ideas.
Unread 17-01-2010, 19:18
Re: completely confused (classmate isue)
I assume you re-imaged the cRIO with v19?
How are you downloading the code?
Use "Run as startup" rather than "Run" for now.
I also assume you clicked Enable on the Driver Station?
What is the status LED on the Digital Sidecar doing - off/solid/blinking?
There is a bug with the Dashboard install, so that can be double checked if you're depending on it to show responses.
You don't need the red USB plug from the USB Hub (doesn't hurt either). That's for greater power, but the black plug alone gives it all you need.
Unread 18-01-2010, 01:59
The Basic FRC cRIO Robot Project was the name of the project from last season. Can you post the version of LV you are running, and the version of the image on the cRIO.
The LV version comes from the Help>>About screen. The cRIO version from the DS Diagnostics tab.
Greg McKaskle
Unread 18-01-2010, 10:28
cRio version is v19
LabView version is 8.6.1
Digital Sidecar lights all solid green
Unread 18-01-2010, 13:15
we (team 379) are getting a 44003 error (camera error) is what i think is our problem
Unread 18-01-2010, 13:22
This week that problem has usually been due to an older version of the Dashboard program that doesn't work with the camera code on the cRIO and doesn't get replaced when the Driver Station Update is installed.
Two solutions to that problem are:
  1. Run the Driver Station Update twice more.
    Once to Uninstall (select "FRC Driver Station" & "Remove this feature").
    Again to Install.
  2. Build your own Dashboard program just by using the LabVIEW default Dashboard project. Example
Unread 18-01-2010, 13:27
Tried 1 working on 2 thanks even if it doesnt work
Unread 07-02-2010, 17:54
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
if someone could close this thread im done with it (dumbdude1994 was unprofessional so i switched it to this user account if someone reads this and knows how to delete an account tell me please)
thanks for all of the help
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
How many teams will have to completely reconfigure there drive train BlackBird11891 General Forum 11 04-01-2009 19:51
Completely new to programming robots... Comatose Programming 4 19-09-2008 19:22
Camera code completely turning off all PWM's Horohoroboarder Programming 10 10-02-2007 19:16
And now for something completely Different... What is love??? Robby O Chit-Chat 81 17-08-2001 14:16
