Go to Post "So [you're] like battlebots" Standard answer: No -- it's better! - Roger [more]
Unread 18-01-2010, 04:06
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Re: Video of Kicker Prototypes
Originally Posted by squirrel View Post
To figure out roughly how big of a cylinder you need based on how much "oomph" you need, figure out how much energy the ball needs as it begins it's trajectory..then figure out how much energy you can get into a cylinder. You only have 60 psi and max 2" bore to work with.
The big issue with air cylinders is that a good kick needs to place an object going at ~25-30 MPH in contact with the ball for about 1/50th of a second with said object having enough momentum that it doesn't lose too much speed during contact with the ball.
Pneumatic pistons have to drive the air in front of them out of the cylinder as they accelerate within it. This often restricts their peak velocity, depending on the orifice size of the cylinder's air exit hole. I don't know if it is allowed, but pulling a vacuum on the cylinder ahead of the piston would effectively give a 15LB pressure boost and seriously increase peak piston speed.
The CFPM capacity of the KOP air compressor also seems much too low to allow very many high power shots. Perhaps using a motor to drive a piston back into a sealed cylinder to built up the air pressure inside to the legal max would allow for both more frequent and stronger shots to be taken in a match.
-RRLedford
Last edited by RRLedford : 18-01-2010 at 04:10. Reason: non-swear verb was flagged/blocked as swearing noun.
Team 1646 Shooter Prototypes Video Ryan Dognaux Robot Showcase 31 25-01-2009 01:17
pic: Team 1501's shooter...errr kicker Wayne Doenges Robot Showcase 9 14-02-2006 14:44
how are those prototypes coming? Solace General Forum 14 18-01-2004 22:19
Watch us build prototypes Joe Canavan General Forum 1 13-01-2002 18:19
