Go to Post Think, Write, Re-Think, Erase or Post - and Deal With it Either Way. - Chris Fultz [more]
Unread 18-01-2010, 08:14
Geek 2.0 Geek 2.0 is offline
FRC #0107
Geek 2.0 will become famous soon enough
Re: Programming the PSoC
Originally Posted by jhersh View Post
The PSoC board has a processor and some reconfigurable mixed-signal logic fabric on board. Basically, you would need to write your own code to run on the board if you use it on the robot.
The expected use case for 99% of teams is that it will be used with the driver station to wire up buttons.
Are we allowed to write our own code for it? I was under the impression that we had firmware given to use by FIRST that we had to use. Didn't see anything in the rules about it.
PSOC Interface Card Lafleur Technical Discussion 4 09-02-2010 13:26
Programming the IR Pi Boy Sensors 3 21-01-2008 15:47
Programming the vex microcontroller to respond to commands on the serial port crashoverride02 Programming 1 20-10-2006 14:17
Programming The CMUcam for the Vex controller 987HighRoller Programming 3 24-06-2006 15:27
Programming the IR James Hine Programming 1 10-03-2004 14:08
