#16
Re: Car Nack Predicts 2010-1
I'm worried you may be right. And with the non-ball end, no doubt. I hope everyone's human players have practice to feed balls up so they can do it slowly and calmly, without whipping that thing around.
#17
On the topic of hanging, those that were around in 2004 remember how fast robots were able to climb the stairs and platforms and hang with just seconds left in a match. I remember robots that were able to hang and lift with seconds left in the matches on a consistent basis using very simple mechanisms. 8 points in the end game, I can see it happening, and I think the regional(s) that I will be able to attend I will see it with my own eyes.
Best of Luck |
#18
I think we wont see it largely because the top team is unlikely to be comfortable supporting 450(ish)lbs from their tower grabber widget. If its beefy enough to hold up 450 lbs of robot, its going to be heavy, and i doubt anyone is going to make that design tradeoff.
EDIT: Unless, of course, the GDC decides to make it more worth our while... like say... a 2nd SUSPENDED ROBOT is worth a 2x or 3x multiplier to either the hanging stack, or the goals scored. |
#20
I don't think it'll be seen because I don't know how much most teams can be trusted to try and attach themselves to someone else's robot without breaking something. The point values don't make it worth it, IMO. |
#21
And a hang was worth 50 points, in matches where most scores were 80-200 points. And if you had a good alliance partner, they could either cap one of your own goals (potentially causing up to a 100+ point increase), uncap the opponents' goal (potentially causing up to a 100+ point swing in your favor), or hang themselves (50 points). There were all single actions, that could have a relatively large swing on the score, which made it easier to deal with one robot being "out of play" because they were on the bar. Since this year's game is soccer, having a complete alliance to keep scoring is much more important. Having one alliance partner "out of play" (because they are hanging) makes it much more difficult for non-hanging alliance partners to do their job and continue to score soccer balls. Hanging may actually negatively affect the potential score your alliance could have scored if you have decent kicker robots and kept on just kicking soccer balls, especially if it takes 30-45 seconds to at least get one elevated and one suspended robot, never mind a second suspended robot for the 8-point hang. At this point, I'm 99.9% sure the GDC will not change the point value of any scored object in the game. Entire robot designs and strategies were all coupled around a specific set of rules. Tweaking these points even slightly would completely destroy some strategies and open up new ones. This would basically waste an entire week of the build season for some teams, if they realized that new point values would make a completely different robot more advantageous. This would cause a massive uproar in the FRC community - "Rabble! Rabble! Rabble!" - which is the last thing FIRST wants right now. |
#22
Say whatever you want, but Car Nack has the track record that makes you stand up an take notice.
Having said that, you will not be surprised to discover that I am sure Car Nack's predictions have merit. Please note that having 2 robots suspended and one robot elevated does not provide +8 points as many have argued!!! To my way of thinking it provides a mere +2 -- the two robots that go from 2pt elevated to 3 point suspended. This is a lot of pain for not a lot of benefit. If these +2 points were free or nearly free (in terms of time and risk), that would be one thing but they aren't. It is quite hard to imagine a situation where 3 robots could configure themselves into an 8 point configuration as quickly and reliably as they could configure themselves in 6 point configuration. Every time I come up with a solution that WOULD provide this advantage, the solution I come up with requires so many resources from the various robots that if they put those same resources into building a robot that does other tasks better, they'd be ahead of the game (by a lot). Callin' 'em as I sees 'em. Joe J. |
#24
We estimate that you can become easily elevated in ten seconds or less for two points. But to pull up high enough to allow another robot to suspend from you would take at least another 6-8 seconds. It would take at least as long for another robot to be suspended. A third robot would take forever.
A robot designed to do nothing other than become elevated and then lift up two other robots is possible (and I think some will try it) but the time needed top do it will allow the other alliance to more than make up the 8 points. |
#25
My personal opinion is that the GDC kind of dropped the ball on this one. As Joe points out, the net benefit from SUSPENDING two robots, as opposed to ELEVATING them is only +2. It needed to be worth substantially more than this for teams to see it as being a worthwhile endeavour.
#26
#27
bingo!
#28
I am envisioning the problem of ensuring that a SUSPENDED robot does not become an ELEVATED robot (or even worse, a hanging robot worth no points). I can think of a theoretical design for the (topmost) ELEVATED robot to accomplish this, but it is quite complex and would probably be weighty. Which might mean that it would be the only thing that robot could reliably accomplish. Worthy tradeoff? Maybe for the "Gee, wow!" factor. |
#29
-dave . |
| Car Nack Predicts #2-09 | Car Nack | Car Nack's Corner | 3 | 25-02-2009 10:24 |
| Car Nack Predicts #2-08 | Car Nack | Car Nack's Corner | 14 | 11-04-2008 10:32 |
| Car Nack Predicts 01/08/07 | Car Nack | Car Nack's Corner | 47 | 22-03-2007 10:07 |
| Car Nack Predicts 04/06 | Car Nack | Car Nack's Corner | 13 | 21-02-2006 13:24 |
| Car Nack Predicts | archiver | 2000 | 2 | 23-06-2002 21:59 |
