Go to Post Leave FIRST? That's an option? =) - treffk [more]
Unread 17-01-2010, 20:30
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Exclamation C-RIO there then not there
Ok I have looked extensively over the past few days and have not found anything related so i was hoping someone could help here is our problem
I am in programing and electrical and was getting ready to run the robot after following the "benchtop" test and i started up the computer and as always the d.s. account came up.
On the status lights the stop button and the communication are green but the Robot code is not (as expected since i have not built a code on yet). I switched
the account over to developer and made a code then proceeded to build it and Run as startup (i'm using labview by the way) but at the end of the Run as startup it stops to tell me that the C-RIO is not connected so i went back to the ds account and it still says that the C-RIO is still connected
Does anyone have any suggestions on what to check for this problem?
P.S. i have run the controls before it was on a robot and it worked fine.
Unread 17-01-2010, 20:42
Re: C-RIO there then not there
Did you set the team number (IP address) when you created the project?
Unread 18-01-2010, 00:13
AKA: Jon
I believe so for 932
10.9.32.2 right?
I will check tomorrow do you have any other suggestions on the cause?
Unread 18-01-2010, 09:41
I'd recommend Exiting out of the Driver account, so it stops it's continuous communication with the cRIO, before using "Run as startup" over in the Developer account.
Unread 18-01-2010, 10:00
AKA: Jon
How can i it runs when you startup the computer and i don't know how to exit out of it
is there a shortcut?
Unread 18-01-2010, 10:02
In the Driver Station on the Setup tab you'll see an EXIT button on the bottom right.
Unread 18-01-2010, 12:52
AKA: Jon
Question Re: C-RIO there then not there
Ok now we have two problems that are alternating
1.the C-RIO says its in use by a host computer or project but only one project is up and the driver is logged off!
2.there is no comms with the c-rio when i try to run as startup
Unread 18-01-2010, 18:31
Please give more details on this problem. When and where is the cRIO saying this, and what exactly is the wording? What does "one project is up" mean?
Unread 18-01-2010, 19:19
AKA: Jon
Ok first the losing comms issue turned out to be a low batt that had enough to communicate until i built and the second issue was just after the Run as startup was hit a message would come up that said "the c-rio is in use by a host computer or project"
Unread 18-01-2010, 21:18
...just after the Run as startup was hit a message would come up that said "the c-rio is in use by a host computer or project"
I'm not familiar with that message. I think you might have miscopied it, because I've never known LabVIEW to spell cRIO that way.
Please let us know exactly what the message says. It's possible that it isn't an error at all, and just a standard warning letting you know that what you're about to do will stop whatever program is currently running.
Is there any North Dakota Teams out there!! team877 General Forum 0 21-01-2008 07:56
Is there a 1001 out there? Shannon Scouting 2 21-02-2003 01:02
I would not stand there RebAl Robot Showcase 13 15-03-2002 20:11
Is there going to be a PBasic emulator out there?? Matt Attallah Programming 7 14-12-2001 13:20
And then there were none... Joe Johnson General Forum 2 21-10-2001 23:31
