Go to Post A great mentor guides without giving the answers, teaches through discovery, demonstrates without lecturing, provides support from backstage, observes without hovering, and leads by example. - dlavery [more]
Unread 18-01-2010, 06:54
yoavh360 yoavh360 is offline
FRC #1690 (ORBIT)
Team Role: Electrical
yoavh360 will become famous soon enoughyoavh360 will become famous soon enough
Crossover Ethernet cable - is it nessecery?
hey !
I did some reading today, and i saw that the Axis camera needs to be connected with a CROSSOVER Ethernet cable instead of a regular one to the cRIO.
Is it that important ? whats the diffrence between regular and crossover cables ?
Thenks !
Yoav,
Team #1690 - "ORBIT"
Israel
Unread 18-01-2010, 07:56
Generator of Entropy
FRC #2973 (The Mad Rockers)
Re: Crossover Ethernet cable - is it nessecery?
The short answer is, yes it is necessary. I don't know the details, but basically, a regular cable has the same wires in the same locations at both ends (pin 1 on the left is pin 1 on the right), where a crossover cable switches positions of the wires (pin 1 on the left might be pin 3 on the right or something like that).
Unread 18-01-2010, 08:10
CrazyCarl461's Avatar
CrazyCarl461 CrazyCarl461 is offline
Power User
AKA: Carl Agnew
CrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant future
Send a message via AIM to CrazyCarl461
Originally Posted by Gary Dillard View Post
basically, a regular cable has the same wires in the same locations at both ends (pin 1 on the left is pin 1 on the right), where a crossover cable switches positions of the wires.
Right. It is needed because the transmit line (Tx) on the cRio needs to be connected to the receive line (Rx) on the camera and vice versa. Many devices such as routers and switches (and anything that conforms to the IEEE 802.3 standard) can perform automatic crossover, but these devices do not.
My 2011 Build Season Blog
Resistance may be futile, but capacitance has potential!
© All content is protected by the honor system
Unread 18-01-2010, 10:10
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
there are two ways to terminate an 8P8C aka RJ45 Jack. a scheme and B scheme
A is white/orange, orange, white/green, blue, white/blue, green, white/brown, brown
B is white/green, green, White/Orange, blue, white/blue, orange, white/brown, brown
to make a crossover you just terminate A on one end and B on the other end. to make a normal cable terminate with similar ends.
FRC #1690 (ORBIT)
If thats the case- is there any diffrence about which end of the cable I connect to which device ? (Camera and cRIO)
Yoav,
Israel
Unread 18-01-2010, 10:18
DonRotolo's Avatar
Back to humble
FRC #0832
If you are using a crossover cable, then no, it doesn't matter which end you connect where.
Unread 18-01-2010, 10:21
AKA: Ty
No. it dosen't matter which side is connected to which. x-overs connect a device to a device. straight cables connect devices to routers/hubs.
Unread 18-01-2010, 10:37
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
So the control system manual shows a crossover going from the cRIO to the wireless bridge and also from the cRIO to the classmate. Are both connections required to be crossover ethernet cables, or can one or both be made with a regular ethernet cable?
Thanks!
Alex
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Unread 18-01-2010, 11:14
Actually, a straight cable can be used for both the wireless bridge-to-cRIO AND for the Classmate-to-cRIO connections. A crossover cable will also work. I know the FIRST documentation says to use a crossover cable to connect the Classmate with the cRIO, but it doesn't appear to be necessary.
Just the camera requires the crossover cable.
Unread 18-01-2010, 11:53
Racer26 Racer26 is offline
This is because the Classmate's Ethernet port has the intelligent crossover (IEEE 802.3). Only one of the devices needs to do it in order for either type of cable to work.
Unread 18-01-2010, 13:36
Blackphantom91's Avatar
Blackphantom91 Blackphantom91 is offline
Mentor + 4 = Stuck For Life
AKA: Malcolm Stirckland
FRC #1986 (Team Titanium)
Blackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura about
Crossovers are to speak to like devices ie the cRio, strait through are for unlike devices, So it is necessary to yse a crossover otherwise your data will not transfer.
Unread 18-01-2010, 14:25
FRC #1690 (ORBIT)
So our link between the Classmate and the cRIO (untill we will configure the wireless) sould also be over a crossover cable ?
Yoav,
Israel
Unread 18-01-2010, 15:05
You can use either type of cable.
Unread 18-01-2010, 22:57
DonRotolo's Avatar
Back to humble
FRC #0832
Because the classmate is smart enough to auto-configure itself.
Unread 19-01-2010, 12:42
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Just nit-picking here... but your lettering is backwards.
TIA/EIA-568-B describes two standards, T568A and T568B:
T568A is white/green, green, white/orange, blue, white/blue, orange, white/brown, brown
T568B is white/orange, orange, white/green, blue, white/blue, green, white/brown, brown
The confusion probably comes from the somewhat twisted (no pun intended) history of the standard. AT&T's 258A standard matches T568B, and is what most people still use for straight cables, mostly out of tradition. In fact, some organizations don't even recognize T568A.
Surprisingly, TIA/EIA-568-B addresses these standards on only one page - the entire document is over 400 pages long. Yet this one page gets more attention than the rest of the pages combined.
For purposes on our robot, all that matters is that you use one standard for one end, the other standard for the other when making a cable to go between the camera and cRio - and as it's been suggested, a straight cable works just fine for the other connections (cRio to wireless adapter, laptop to cRio, etc). However, if you're every doing wiring on a broader scale, the standards do matter. Horizontal cable runs should terminate with T568A, while vertical runs should terminate with T568B, officially.
And finally, a short description on why all of this is necessary, with an emphasis on history. Back when all of this was new, it was pretty expensive to do any autodetection/switching- in fact, no one did it. Instead, they basically defined the ethernet jacks on computers to "expect" transmission on one pair, reception on the other. Since most computers were then plugged into a hub, they physically swapped it on the ethernet jacks on the hub - this way, a straight cable would work between the computer and a hub. The hub expected the reception on the same pins as the computer was transmitting, and vice-versa. But sometimes people wanted to connect computers straight to other computers, or hubs to other hubs. In order to do that, the crossover cable was invented, where the reception/transmission lines were swapped in the cable, instead of in the port the cable was plugging into.
Of course, some devices can now autodetect what the device on the other end is doing and adjust. but that's more expensive to do, so some devices, like the Axis camera, don't bother. The assumption made when they designed the camera was that it would always be plugged into a router. Turns out that's not a great assumption when FIRST picks it up
Ethernet question Ushio FRC Control System 2 17-01-2009 13:58
Ethernet camera kamocat Programming 9 06-09-2008 08:09
EasyC in crossover Kyle Fenton Programming 4 10-01-2007 09:10
Embedded Ethernet? Andrew Blair Technical Discussion 6 22-06-2006 21:12
