Go to Post The gearbox can be anything, just as long as it weighs less than 0 lbs, and yes, I'm talking about negative weight here. - NoodleKnight [more]
Unread 18-01-2010, 11:58
PortugazD.Ace's Avatar
PortugazD.Ace PortugazD.Ace is offline
AKA: Timothy Gonzales
FRC #1165 (Team Paradise)
Team Role: Student
PortugazD.Ace is an unknown quantity at this point
Rotary Encoders
Does anyone know how to connect the US Digital Rotary Encoder to the cRIO? Or how to set up the cRIO to be able to use it? Same questions for the Austria Microsystems Magnetic Rotary Encoder.
Unread 18-01-2010, 13:29
Integral Integral is offline
AKA: Ross
FRC #1130 (Robo Rebels)
Integral is an unknown quantity at this point
Re: Rotary Encoders
I use 3 cables for 2 encoders, one is the power cable using a female PWM with the Red wire tied to the Orange (5v) wires from each encoder and the black wire soldered to the Brown wires from the encoders, the white wire on the PWM cable is unused.
For the channel A and B, I cut in half a 2 pin solenoid cable and solder the yellow and blue wires form the encoder cable to the red and white wires of the 2pin cables. The power cable can go to any empty digital input, the 2 cables with A and B outputs are then connected 90 degrees from the normal orientation to adjcent signal pins. It requires 4 digial I/0 ports to use the encoders.
combined Team 1130/957
Unread 18-01-2010, 13:56
Team Role: Student
Re: Rotary Encoders
Thank you for the information. If you have any ideas on other ways to set up the rotary encoders, please post.
Unread 18-01-2010, 14:22
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: Rotary Encoders
Another approach is to use 2 PWM cables......Cable 1 has channel A (white) and power (red)....the other channel B (white) and ground (black).
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 18-01-2010, 19:19
Re: Rotary Encoders
The Sensor Manual on the FIRST web site gives some answers, along with pointers to more information. Find it next to section 8 of the Game Manual.
http://www.usfirst.org/roboticsprogr...nt.aspx?id=452
What programming environment are you using? LabVIEW has complete example code for using the encoders.
Unread 22-01-2011, 17:47
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
Re: Rotary Encoders
For the rotary encoders, we snipped some wires from the digital side car and soldered the orange to the red (postives), the brown to the black (ground), and the blue to the white (signal)
Then we just plugged it into the digital sidecar
How to mount rotary encoder Logan Williams Electrical 13 12-01-2009 20:00
Rotary Position Sensors DonRotolo Electrical 10 21-11-2005 15:03
Rotary Encoder Collars team222badbrad Technical Discussion 1 09-11-2005 19:14
Rotary Encoder (optical etc.) Gary C Technical Discussion 4 16-01-2005 18:23
Rotary Actuator Wetzel Pneumatics 4 09-02-2004 21:11
