Go to Post I suppose this would be a bad time to reveal that Q and LookingForward are the same robot person hybrid thing... - EricVanWyk [more]
Unread 18-01-2010, 13:09
brianc217's Avatar
brianc217 brianc217 is offline
None #1153
brianc217 is an unknown quantity at this point
Ellipse Finding/Edge Detection Example Code?
Can someone give me detailed instructions on where to find the Ellipse finding vision code examples and the edge detection sample code for LabVIEW? Everyone is talking about how they give it to you right in the vision VI but I can't seem to find it. Any help would be appreciated.
http://walpolerobotics.org
Unread 18-01-2010, 13:20
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: Ellipse Finding/Edge Detection Example Code?
It will be there after you do the mandatory update.
http://joule.ni.com/nidu/cds/view/p/lang/en/id/1534
-- Marshal Horn
Unread 19-01-2010, 16:36
brianc217's Avatar
None #1153
Yes thank you...we found the vision code after we did the update but is there also edge detection/ line follower code? And if so, what VI is it in?
Unread 20-01-2010, 08:57
The Vision code makes a call to Find Circular Target which calls into IMAQ to find ellipses, normalizes, etc.
There is no code in the sample to follow lines. If you are interested, there may be some examples in the IMAQ folder, or ask and I'm sure you can get some help.
Greg McKaskle
Ellipse/Shape Detection with Java cheeser180 Programming 1 17-01-2010 10:50
Team 67 C++ Example Code David Doerr FRC Control System 11 23-11-2008 18:14
Ganged Interrupt Edge Detection cprogrammer Programming 8 01-02-2008 10:52
Example code TEAM1949 Programming 10 15-03-2006 16:00
Autonomous Code Example Matthew_H Robotics Education and Curriculum 24 21-11-2003 10:02
