Go to Post CAD is the oxygen for engineering. - Bharat Nain [more]
Unread 16-01-2010, 07:21
yoavh360 yoavh360 is offline
FRC #1690 (ORBIT)
Team Role: Electrical
yoavh360 will become famous soon enoughyoavh360 will become famous soon enough
About the 206 Axis Camera
Hey guys !
Im having some tough time connecting the cam that cam with the kit.
i cant figure out where to connect the servos to...
I know that they need to be connected to the SideCar- But WHERE TO ?
thenks in advance,
Yoav.
Team #1690 - "ORBIT"
Unread 16-01-2010, 07:59
Back after 4 years off
FRC #5279
Re: About the 206 Axis Camera
They connect to the pwm outputs, the same place that motors connect to. I believe the sample code uses pwm 1 and pwm 2.
-James
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 16-01-2010, 08:14
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
When connecting servos to the sidecar, don't forget you have to install jumpers to make the PWM outputs servo outputs.
Former Mentor Team 1771
Former mentor Team 4509
Unread 16-01-2010, 11:05
etphonehome etphonehome is offline
FRC #0537
etphonehome is an unknown quantity at this point
Step by step for servo connection:
1) wire power to the port on the digital sidecar
2) plug servo into pwm port
3) put jumper on the 2 prongs next to the port you selected (jumper is the same as the one you put on analog breakout for battery monitoring)
Unread 17-01-2010, 09:30
richwong richwong is offline
None #1701 (Robocubs)
richwong is an unknown quantity at this point
We have the same question. What PWMs does the default code use for the camera servos? It's not 1 and 2, because the default code uses those for the drivetrain.
Unread 17-01-2010, 10:02
The LabVIEW default code does not use the servos.
Unread 17-01-2010, 10:13
What language are you using to program?
In LabVIEW the default code isn't setup for driving the camera mount servos, but the servo camera example code is.
P.S. Sorry for my delayed response. I didn't mean to give the impression I ignored Joe's post. I just left my post sitting for 15 minutes while I went off and fixed my flaky Verizon DSL Internet connection, while Joe answered.
Unread 18-01-2010, 14:44
FRC #1690 (ORBIT)
cant figure out what jumpers are...
can you give some detail/picture ?? thenks!
Yoav,
Israel
Unread 18-01-2010, 15:14
They are tiny, ~ 1/8 inch long, and are in one of the zip lock bags jumbled together with other parts. They could be colored black as in the KOP Checklist picture or white or another color.
Axis 206 Web Camera no longer in production Ragnarokae Kit & Additional Hardware 12 10-01-2010 15:59
Need help with Axis 206 Power Adapter dipmeinaluminum FRC Control System 1 21-01-2009 20:01
Programing servo in Axis camera 206 frcchile NI LabVIEW 6 18-01-2009 08:53
Programming the axis camera...... programmr C/C++ 10 11-01-2009 12:23
Focusing the AXIS camera in LV Bryan Herbst Programming 3 03-01-2009 23:21
