Go to Post Team Titanium's trying Teeter Totter Talons tying the terrain traversal tandoming Twin Tucking Tabs to try triples. - [more]
Unread 18-01-2010, 13:54
NinJA999's Avatar
NinJA999 NinJA999 is offline
Chipmunk NinJA
AKA: Nick Aldwin
FRC #0811 (Team 811)
NinJA999 will become famous soon enough
Send a message via AIM to NinJA999
Best way for "servo" from motor & potentiometer?
This year one of our structures on the robot will need precise control over a motor's positioning. We'd like to hook up a potentiometer to the motor and use it like a really high powered servo (an encoder would be another option; however that offers relative rather than absolute positioning). What would the best way to code this be? Should I create a new class which uses a Jaguar and an AnalogChannel and does some fancy PID routines to provide accurate positioning? Am I missing a something in the library which already does this or something similar? (I'm not talking about the built in Servo class -- that's meant for servos connected to the digital sidecar) Any ideas/input would be helpful! Thanks!
Team 811 (Nashua, NH) - Mentor
Previously Team Lead & Programming Lead
Unread 18-01-2010, 14:12
Jared Russell's Avatar
Taking a year (mostly) off
Re: Best way for "servo" from motor & potentiometer?
Probably the easiest thing to do would be to make a PIDController object with the PIDSource set to the analog input corresponding to the potentiometer, and the PIDOutput set to the Jaguar/Victor controlling the arm.
Look at the documentation for PIDController to see exactly how to do this.
Unread 18-01-2010, 14:50
NinJA999's Avatar
Chipmunk NinJA
AKA: Nick Aldwin
Do I need to have a tightly controlled time loop to use the PIDController? What's the best way to do that?
Unread 18-01-2010, 14:54
The WPILib implementation of PIDController actually does all of its processing in a separate thread in the background - you just tell it to start (and stop), and where to go to, and it does the rest.
Unread 18-01-2010, 16:14
NinJA999's Avatar
Chipmunk NinJA
AKA: Nick Aldwin
Nice, thanks so much for your help!
Team 1943 - "Neat-Team" - From Rosh Haayin, Israel. BEST ROBOT EVERRR!!! Gal Yaad Robot Showcase 7 05-04-2008 05:44
White Paper Discuss: "18 Tips for in the Pits for FIRST Teams" RoboMom Extra Discussion 2 11-02-2006 19:42
pic: My vote for the best design from the team spirit "drawn" in the stands. CD47-Bot Extra Discussion 4 07-09-2004 00:19
Conflict between "Initialize_Tracker()" and "pwm13 & pwm15"? Kevin? gnormhurst Programming 3 22-02-2004 02:55
