Go to Post FIRST: there is no second. - BandChick [more]
Unread 18-01-2010, 19:01
ttldomination's Avatar
Sunny
Solenoid Control Valve Question
Hello Everyone,
First off, I'm an extreme noob when it comes to pneumatics, so I apologize for any stupid questions.
My question for today is that my team is having a little bit of trouble with the kicker.
We're using cylinder with a 9" stroke and I believe a 2" bore. We're trying to use the festo solenoid control valves that were provided in the kits. Actually, I think we're using the '09 valves.
We can't seem to get a decent kick out of the system. Now an obvious change was to use a cylinder with a smaller bore and a shorter stroke, but some of our mentors also suggested getting a valve with a large flow rate.
Now, I'm wondering those of you who are using pneumatic kickers, what kinds of valves are you having success with? Or if you are using pneumatics, which valve would you recommend?
1648: 2013-2014
5283: 2015
Single vs double solenoid valve operation Scott358 Pneumatics 0 29-01-2005 11:47
SMC Double Solenoid Valve Assembly Dave Kempskie Pneumatics 0 29-01-2003 13:34
Will trade for double solenoid valve archiver 2001 2 24-06-2002 00:33
Dismantle Solenoid valve? archiver 2001 2 23-06-2002 23:34
Single Solenoid Valve SMC Chubtoad Technical Discussion 3 20-01-2002 15:16
